Old 05-29-2022, 05:22 PM   #1
dstoverud
Default 1930 Model A diaper pan
My diaper pan collects quite a bit of oil, and if not careful, sloshes out and onto the road. What is the cause of abnormal amount of oil? Crankcase dipstick is 1/2 full today, and I have to remove and empty this pan much too often. If this a big repair?
Thank you!
dstoverud is offline   Reply With Quote
Old 05-30-2022, 10:32 AM   #2
katy
katy's Avatar
Default Re: 1930 Model A diaper pan
"What is the cause of abnormal amount of oil?"
Assuming you mean "oil leak?", it's usually either a sloppy rear main or missing gasket between the block and flywheel housing.
Old 05-30-2022, 11:58 AM   #3
dstoverud
Thank you, Katy. It didn't use to leak this bad, so I'm thinking the gasket is there, but maybe worn out, or your suggestion the rear main. I hatge to think of pulling the whole engine.
Old 05-30-2022, 12:35 PM   #4
TomInCologne
TomInCologne's Avatar
overfillin' the engine with oil...
Don't ask me how i found that out....
TomInCologne is offline   Reply With Quote
Old 07-20-2022, 03:02 PM   #5
Ruth
Hah!! I wonder how many have done THAT on their first oil change (and are willing to admit it!).
Ruth
Old 06-21-2022, 08:17 PM   #6
Synchro909
Synchro909's Avatar
Don't be too afraid of pulling the engine. It's been done many millions of times often by people who are as mechanically apt as a house fly.
If it has to come out, take it out or you will likely never get it fixed. JMHO.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 05-30-2022, 03:42 PM   #7
eagle
eagle's Avatar
Are you using synthetic oil? If you have a marginal issue synthetic oil will make is much worse. I use 15-40 diesel tractor oil.
Old 06-14-2022, 01:51 PM   #8
dstoverud
I'm using that too, thanks. Tempted to use some STP!
Old 05-30-2022, 09:50 PM   #9
Bill G
Bill G's Avatar
A clogged or blocked off oil filler pipe or breather cap would cause this too.
Old 06-14-2022, 01:50 PM   #10
dstoverud
Yeah, I cleaned that up too. Thanks.
Old 07-20-2022, 09:49 PM   #11
old ugly
old ugly's Avatar
this is the easiest thing to check, just pull that oil filler cap off and make sure there is no obstruction in the cap or filler tube. engine pressure will pump oil rite out that main bearing.
always check the easy stuff first we should not instantly jump to pulling the pan and checking bearings.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 05-30-2022, 10:54 PM   #12
daveymc29
daveymc29's Avatar
Fitted the roadster with a roaddraft tube oil filler. Could that cause the adverse effect seen by the above posts?
daveymc29 is offline   Reply With Quote
Old 06-14-2022, 02:51 PM   #13
WHN
Is this a high mileage engine?
What weight oil are you using?
I have never owned a Model A that did not mark its spot. Just a couple of drips, not a puddle.
On higher mileage engines. I have been using 20W-50 HD oil with one blue bottle of STP.
This formula has worked well on oil dripping issues. Also engine noise. Thinner oil, increased oil dripping.
Enjoy.
Old 06-21-2022, 09:20 AM   #14
dstoverud
Thank you...I'll try your formula! Been using 15-40 Diesel oil.
Old 06-21-2022, 03:08 PM   #15
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Have someone step on the clutch while you watch the front pulley. You should only have less than .005” movement, and that’s stretching it. I’ve seen some with .020” ,which allows a pretty good rear main leak. You can also undo the three bolts that hold the inspection cover to the fly housing, which then allows you to run the engine while looking for oil leaking at the back of the rear main bearing.
Old 07-20-2022, 02:15 PM   #16
dstoverud
Thanks, I'll do that!
Old 07-20-2022, 02:17 PM   #17
dstoverud
Is the inspection plate under the floor board?
Old 07-20-2022, 02:25 PM   #18
Y-Blockhead
Y-Blockhead's Avatar
Underneath the car on the clutch cover.
Old 07-20-2022, 02:28 PM   #19
Y-Blockhead
Thank you!
Put a large feminine napkin in the janitor and change it once a month or as needed.
Old 07-20-2022, 02:34 PM   #20
jack backer
If your rear main bearing clearance being too great is causing your leak adjust your main bearings. Or ignore it and suffer complete bearing failure and the resulting cost, it’s up to you.
jack backer is offline   Reply With Quote
