Old 07-12-2022, 01:14 PM   #1
packrat6
Default Compression question.
The engine in my '30 Fordor was rebuilt some while before I bought the car. I tracked down the son of the man who had had the engine work done but he did not know much about it.
In doing a compression check, I find the readings at about 110# across all four cylinders. What would have been done to this engine to achieve that kind of head compression??
packrat6 is offline   Reply With Quote
Old 07-12-2022, 01:25 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Compression question.
I would think that monster has one heck of a cylinder head on it, maybe two.m[smiley face]. The deck may have been cut quite a bit too. It could make a difference what pistons it has in it.
But, as long as the starter is working,,,,,,,
Old 07-12-2022, 03:21 PM   #3
AzBob
FWIW, I am running a new Snyder's 6.0 head, .060 over pistons and have ~ 105 psi. across all 4.
AzBob is offline   Reply With Quote
Old 07-12-2022, 03:31 PM   #4
nkaminar
nkaminar's Avatar
Packrat, Any clue as to what head is on it? Maybe a photo would help.
Old 07-12-2022, 05:12 PM   #5
jack backer
Could be a faulty compression gauge..
jack backer is offline   Reply With Quote
Old 07-12-2022, 08:17 PM   #6
Synchro909
Synchro909's Avatar
One of my touring engines has a 5.5:1 head on it but it has been off a few times. I have it machined for flatness each time so who knows where it is now. That engine gives me about the same figures as the OP and it's done about 45,000 miles towing a camper that weighs about the same as the car at 50 mph and it's still going.
Your car will have more zip than most with that compression so I suggest you enjoy the heck out of it as it is. Just don't over advance to timing. I'm sure someone will advise what the maximum advance should be but my guess is about 20°.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 07-12-2022, 08:20 PM   #7
Gene F
Gene F's Avatar
A higher compression also runs a little bit cooler too. Seems odd, but it works that way...
Old 07-12-2022, 08:33 PM   #8
Synchro909
Synchro909's Avatar
Yup, combustion is more efficient. More go for less $.
My Burtz engine is running a 6:1 head, cam shaft from a local regrinder - 0.308" lift (I don't have the timing with me at the moment) and a Webber carburettor. At 85-100 kph (53 - 62 mph), it turns in 27 mpg. That's imperial gallons (about 23.7 miles per US gallon). I'm very happy with that. I made a stop on the side of the distributor to limit the advance to 22° - perfect. I'm considering a thermostat for it but so far, over my 4 Model As and several attempts, I have not found one that works anywhere near the way it is supposed to. The worst was a 180° T/stat that opened at 145°. Does anybody make a decent one?
Old 07-13-2022, 06:17 AM   #9
nkaminar
nkaminar's Avatar
Synchro, If you do use the thermostat that is mounted in the output hose, drill some holes in the flange so that there is some circulation when it is closed. The thermostat will operate better. Otherwise it will open in bursts causing the engine temperature to fluctuate and the coolant to escape out the overflow pipe when the slug of hot coolant gets into the radiator. Plus it keeps the head temperature more uniform.
Old 07-13-2022, 07:48 AM   #10
Bob Bidonde
Bob Bidonde's Avatar
There is a 6:1 cylinder head on one of my engines, and it has compression readings of 115 to 117 psig.
Bob Bidonde
Old 07-13-2022, 08:48 AM   #11
jack backer
Increasing volumetric efficiency through performance upgrades results in an engine that runs cooler and doesn’t have the common failures that stock engines do…burned exh gaskets, warped manifolds and failed condensers (from heat) to name a few..
Vintage precisions thermostat housing support the thermostat correctly, instead of lodging it in the hose. This stability decreases binding and warping during heat cycles, insuring accurate opening temps.
Old 07-13-2022, 02:02 PM   #12
Herb Concord Ca
i have the Vintage Precision thermostat on both my Model As. It's pricy but worth it.
Herb Concord Ca is offline   Reply With Quote
Old 07-13-2022, 02:31 PM   #13
ETAModel
Why install a thermostat on a motor that comes to operating temperature so quickly and wasn't designed to operate with one? I'm new to the A, trying to soak up all the info I can.
ETAModel is offline   Reply With Quote
Old 07-13-2022, 05:34 PM   #14
Big hammer
Because if you have a radiator that cools well and you drive at temperature below 60*F the engine will not get up to operating temperature
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 07-13-2022, 06:07 PM   #15
jack backer
And when an engine doesn’t get to proper operating temperature increased engine wear is the result, along with inefficient combustion, the two issues work together to shorten engine life. It’s why every modern engine one.
Old 07-13-2022, 07:36 PM   #16
Synchro909
Synchro909's Avatar
Perhaps I should have mentioned that I have always drilled 3 x 1/8" holes in the T/stat, even before it was mentioned here.
Old 07-14-2022, 12:18 AM   #17
Lawrie
Lawrie's Avatar
Get a modern t/stat, tig weld it to a short length of SS tube that will fit in the top hose,Hey presto a modern t/stat that works. All my old rockets have them in , take a look on the v8 side and see how the 33 went out west this last month.
Lawrie
Old 07-14-2022, 09:30 AM   #18
Benson
Lawrie
I agree with the thermostat in the hose with the sleeve (AND a clamp) to keep it from moving up the hose or turning around "Bass Aackwards" like a stat without the sleeve will do..
Berts has been selling these sleeved stats for at least 20 years.
I used a version of this setup since 1963.
It was a tractor thermostat inside a housing which I installed in upper hose after cutting 3 or 3 1/2 inches out of the hose. Was made in Holland ... I still have it in the garage.
After 50,000 miles it finally gave up the ghost.
I now have the Vintage Precision housing since whenever they introduced them.
