01-10-2023, 03:26 PM | #1 |
main bearings
I'm putting a 53 merc crank in a 1940 block, which main bearings 38 t0 48 or 49 to 53, do i go by the crank or by the block ?
thanks kurt |
01-10-2023, 03:59 PM | #2 |
Re: main bearings
block for mains. Rods need insert bearings for 8BA-style rods.
01-10-2023, 04:29 PM | #3 |
Re: main bearings
Yes, as above, mains always go with the block. FWIW for anyone with a French block, even though produced after the 8BA series, the mains are the 59A type.
01-10-2023, 06:41 PM | #4 |
Re: main bearings
If your installing a Mercury crankshaft in a 40 block it must be bored to 3 3/16” or the rods won’t fit down the hole.
01-10-2023, 09:17 PM | #5 |
Re: main bearings
Also, change the pot-metal rear-main seal retainers to the later ones . . . as you now need the rope seal. It may or may not have the correct plates (top and bottom). As Ken noted, it is best to bore the block to 3.187 - so the later 8BA rods fit through the bores - otherwise it is a considerable main to try to put the pistons/rods in from below and then attempt to put the crank in!
01-10-2023, 10:32 PM | #6 |
Re: main bearings
My 81A block was real close to touching after boring to 3.187. |
01-11-2023, 10:47 AM | #7 |
Re: main bearings
I intend to bore to 3 3/16 and use the 8ba rods
01-11-2023, 10:51 AM | #8 |
Re: main bearings
I am building basically the exact same engine (40 block, merc 4” crank, 3 3/16 pistons). What can and carbs will you be running?
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ |
01-11-2023, 01:52 PM | #9 |
Re: main bearings
Whatever makes you happy! I tend to run dual Stromberg 97's on this combination - probably with an Edelbrock Slingshot manifold -- so I can run the generator in the stock location.
01-12-2023, 05:35 AM | #10 |
Re: main bearings
That’s exactly what I'm doing but I have Stromberg 48s with 97 tops and bottoms and an Iskey 77B cam which should be pretty close to stock 8BA cam. I also have a late merc 8BA cam modified to fit an early engine for a letter build.
01-12-2023, 10:00 AM | #11 |
Re: main bearings
Just to add to the discussion, the front and center main is the same 8ba or 59a it is the rear one that is different.
