Old 05-06-2022, 05:34 AM   #1
Tony Burdett
Default Door skin “ oil canning “
Before it all fell off into a bottom of the door my F1 doors had a bitumen like material stuck to the inside of the skin, I don’t know if this will help with the problem but does anyone know what it was and what do people use now, thanks.
Tony Burdett is offline   Reply With Quote
Old 05-06-2022, 07:12 AM   #2
alanwoodieman
Default Re: Door skin “ oil canning “
sound deadening, sort of like a tar substance, a lot people glue an insulation materiel in it's place or even spray on undercoating
Old 05-06-2022, 08:48 AM   #3
19Fordy
19Fordy's Avatar
Here's what folks are now using as sound deadening material. It's a "peel and stick self adhesive" covering.
https://www.google.com/search?q=car+...hrome&ie=UTF-8
Old 05-06-2022, 11:10 AM   #4
cas3
I used a peel and stick stuff thats for patching leaky gutters. Available at lowes, 6" wide rolls, very cheap compared to the dyna mat type of products.
Old 05-06-2022, 01:04 PM   #5
Lawson Cox
Lawson Cox's Avatar
Get a gallon of roofing patching cement at Home Depot, it comes closest to matching original product, cheap and easy to apply.
Old 05-06-2022, 02:03 PM   #6
Oldbluoval
Oldbluoval's Avatar
Adding back the coating will help with tin canning but not solve. Has there been visible body work on the skin? Sounds like some shrinking might be in order.
Old 05-07-2022, 08:06 AM   #7
Frank Miller
Frank Miller's Avatar
If he used heat to remove the tar like substance he may have to stretch it a bit. Sounds counterintuitive but it is hoe it works.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 05-07-2022, 08:58 AM   #8
Oldbluoval
Oldbluoval's Avatar
I use a heat gun…..no flame..to remove that stuff when necessary. Heating only to soften and scrape with putty knife. Yes too much heat does sheet metal wrong!
Old 05-07-2022, 03:00 PM   #9
deuce_roadster
deuce_roadster's Avatar
Before you embark on any shrinking or stretching, THOROUGHLY understand what is happening with the metal, where and why. I have had to fix things a novice tried to "rough in" or save time which did the opposite. Just sayin. Maybe you know someone with experience that can help and teach you how to remove the oilcan.
If you look at my MISC folder, you will see the job (my 34 sedan delivery) that taught me the most, with lots of advice from old time bodymen as to what to do first and why.
Old 05-07-2022, 06:00 PM   #10
KiWinUS
KiWinUS's Avatar
Listen to Duece Roadster. Did the insulation coating on inside of doors get blasted to remove? If so there’s the problem. (Ask me how I know). Very difficult to fix. Adding insulation material back will not fix it.
Old 05-07-2022, 09:28 PM   #11
3twinridges
3twinridges's Avatar
On our F1 build, the media blaster tried to clean all that off and warped the sheet metal. Our sheet metal guy had to add supports inside the door to hold the crown. Panels like the hood and doors, and even the back of the cab are really sensitive and prone to warping.
JB
3twinridges is offline   Reply With Quote
Old 05-08-2022, 01:51 AM   #12
aussie merc
aussie merc's Avatar
yes fix the problem 1st but as to what to apply afterwards there are several choices 1 body shutlz [black spray on stuff often used as salt proofing] 2 spray on body [tub] liner 3 cork gasket sheeting or floor tiles 4 sound deadening or carpet underlay etc etc the choice is as endless and varied as your imagination sometimes to reduce noise and others to insulate against heat or cold at sixty five with 50 years around transport i still get amazed with human ingenuity around problems [got told years ago "open your eyes shut your mouth and learn if it works it aint stupid"
aussie merc is offline   Reply With Quote
Old 05-08-2022, 10:29 AM   #13
john worden
john worden's Avatar
Is the problem oil canning or bitumen failure?
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa.
john worden is offline   Reply With Quote
Old 05-08-2022, 12:21 PM   #14
Henry Hopper
Henry Hopper's Avatar
Did 32 roadsters come from the factory with the bitumen coating inside the body?
File Type: jpg 6EB60074-DAE7-4C7C-A692-4155D7757373.jpg (33.9 KB, 29 views)
Henry Hopper is offline   Reply With Quote
Old 05-08-2022, 01:21 PM   #15
deuce_roadster
Good question for DavidG. Mine was so rusty I couldn't tell.
Old 05-09-2022, 10:49 PM   #16
Flathead Fever
Flathead Fever's Avatar
Before a panel is painted you can heat a few small heat shrink spots red hot, one at a time, the size of a dime and quench them with a wet rag. I have really small #00 an #000 gas torch tips I use so I don't overheat the panel and warp it too bad. Just a few of those well placed heat shrinks and the skin will get as tight as a drum. You might want to explain to anybody under 30 what oil-canning is since they grew up with plastic oil bottles. I showed my 35-year-old son-n-law an oil can spout and said," what's this tool used for". He didn't have a clue. He can't inherit my cars or my tools. My best hope is to teach my 4-year-old grandson about how things worked in the "olden days".
Old 05-10-2022, 02:45 AM   #17
Henry Hopper
I had a 40 coupe years ago ... it was an unfinished project and was painted bright yellow. I didn’t like the colour and stripped it off😣... the body was solid but some moron had sand blasted it and wrecked every panel on the car. I used a small oxy- propane torch to heat shrink the damaged areas just to get some integrity into the metal to allow the panels to be filled. My metal working skills didn’t stretch to repairing back to factory finish and it took me ages to get that car straight enough for paint.
When I’d done with the heat and shrink the body looked like a leopard , covered in penny sized blue dots all over it.
File Type: jpeg 510DD8D4-06AF-4506-A250-56C246E582FC.jpeg (68.9 KB, 12 views)
Old 05-12-2022, 02:29 PM   #18
john worden
"Oil canning" class now in session......
Oil cans of old (see pic) had a bottom that was stretched which when pressed would flex forcing oil out of the spout. The bottom would then return to the pre flexed condition.
The flexing is identical to what a stretched body panel will do when pressed.
In severe conditions the panel may remain in the flexed low/high, in/out position however.
There are various heat shrinking methods that can help bring the stretched panel back to or close to the original contour depending on some conditions.
Old 05-13-2022, 05:34 PM   #19
mercman from oz
mercman from oz's Avatar
Description of "Oil Canning" by john worden - see above Post
mercman from oz is online now   Reply With Quote
Old 05-13-2022, 09:57 PM   #20
john worden
Thank you mercman from oz.
