Old 04-25-2022, 07:48 PM   #1
1948F-1Pickup
1948F-1Pickup's Avatar
Default 8BA flywheel housing retainer and seal
Engine builder didn't install the item circled in red in the photo below.....
it was returned to me in a plastic bag. They did run-in the engine after it
was assembled on a test stand. No leaks or problems.
Any issue with not running the plate pictured below?
Thanks.
1948F-1Pickup is offline   Reply With Quote
Old 04-25-2022, 08:50 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 8BA flywheel housing retainer and seal
This info. may help. Contact Mac Van Pelt to make sure.
https://www.jalopyjournal.com/forum/...-help.1040247/
Is that part used only with the cast iron truck bellhousing that connects the engine to the
transmission?
Old 04-25-2022, 09:16 PM   #3
tubman
tubman's Avatar
"19Fordy" is correct. That is a truck only part. What are you working on?
Old 04-26-2022, 10:46 AM   #4
1948F-1Pickup
It's a '48 F-1 239 flathead.
There's no doubt it was on the engine beforehand when I gave it to H&H and
it was returned to me in a plastic bag when I picked the engine up, as I mentioned. Two short bolts are installed in the oil pan rail where this item
originally was. The engine was run on their stand before I picked it up.....
I'm assuming this piece is redundant.
I see the two seals are available from Mac van pelt. (8RT-6425 AND 8RT-6424)
Old 04-26-2022, 12:24 PM   #5
19Fordy
19Fordy's Avatar
Look at the photos of this oil pan for sale and you will see the bolt holes for that piece.
https://www.ebay.com/itm/39399621201...evt=1&mkcid=28
My 1950 Mercury stamped steel oil pan has similar bolt holes and bracket attached to the oil pan. As you can see the 2 bottom bell housing bolts go through those holes. Your situation may be similar. Hence, the piece you ask about is not needed.
Old 04-26-2022, 12:39 PM   #6
1948F-1Pickup
Thanks for that 19Fordy.
I have the truck oil pan and see how the 6410 piece bolts up. I'll leave it off the engine.
