04-04-2022, 02:18 PM | #1 |
Transmission hump oval hole plug
So I can find the 1.5 inch and 1,25 inch plugs but cannot find the oval plug anywhere. It measures 3.7 x 1.93 inches. Only thing I find is part number 12128. I can find this at Larrys T-Bird but does not say it will work on the car also. Anyone know if this is the same as for the full size car?
04-04-2022, 04:58 PM | #2 |
Re: Transmission hump oval hole plug
https://cimg3.ibsrv.net/gimg/www.for...82a94d587a.jpg Just a picture for reference. 73 to 79 Ford trucks, right in the center of the cowl is oblong rubber plug. Not sure if its your exact size, but they all have one. 2 more of another size on the sides of the cowl down lower.
04-05-2022, 03:07 AM | #3 |
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
04-05-2022, 12:16 PM | #4 |
They do not have it. The ones in the link are smaller then the original.
I found one at Larrys T-Bird but do not know if it will work on the full size car. Inquired to see what they say. Last edited by 56sedandelivery; 04-05-2022 at 12:28 PM. |
04-05-2022, 12:37 PM | #5 |
Where does the plug go, on the trans tunnel or floor pan?
04-05-2022, 03:53 PM | #6 |
04-05-2022, 08:30 PM | #7 | |
As near as my trifocals can see my trusty tape measure, this hole in the trans hump of a '57 Bird measures 3 & 5/8 by 1 & 15/16 inches. Last edited by dmsfrr; 04-05-2022 at 08:42 PM. |
04-06-2022, 01:20 AM | #8 | |
EDIT - Found It! Had to go to early MPC ISSUE - Not in FINAL ISSUE B5A 7012128-A Same as BIRD.
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS Last edited by KULTULZ; 04-06-2022 at 03:02 AM. |
04-06-2022, 09:35 AM | #9 |
OK Found that at Concours so have it on order. Thanks
04-06-2022, 09:52 AM | #10 |
Yes, just to confirm.
additional illustration at this link... https://www.classictbird.com/Plug-Fl...uctinfo/12128/ |
04-06-2022, 12:05 PM | #11 | |
!!! Thanx !!!!
04-07-2022, 01:47 PM | #12 |
i have a couple of holes like that in my mustang i have the plugs in the garage i will measure them and get back to you
04-07-2022, 05:31 PM | #13 | |
https://www.steelerubber.com/body-ho...kit-20-2706-20
04-09-2022, 03:18 PM | #14 |
For everyone's knowledge the one for the T-Bird is the same as for the car. Bought one and it is a perfect fit. Only difference I see is the original has a metal insert in it and the new one does not.
04-10-2022, 06:35 AM | #15 | |
