Old 03-05-2022, 12:31 PM   #1
cavalierhome
cavalierhome's Avatar
Default Leaking Carburetor leak found HOW can I fix this?
So, I found my carburetor leak, the cap jest is stripped out and leaking, the bottom of the carb is striped out. Are there oversized Cap jest or a way to insert a new thread into the bottom?
Any Idea apreciated.
Cheers
cavalierhome is offline   Reply With Quote
Old 03-05-2022, 12:38 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Leaking Carburetor leak found HOW can I fix this?
J-B Weld if nothing else is offered.
Old 03-05-2022, 02:32 PM   #3
cavalierhome
I think that is what they had used before and it let go.
Cheers
Old 03-05-2022, 02:40 PM   #4
cavalierhome
I would use a helicoil but I don't know what size the tread on the Cap jet is.
Old 03-05-2022, 03:01 PM   #5
Brentwood Bob
Omit.
Brentwood Bob is offline   Reply With Quote
Old 03-05-2022, 03:04 PM   #6
cavalierhome
Originally Posted by Brentwood Bob View Post
Replace the bottom casting.
I have several.
I sent you a pm.
I don't see a PM
Old 03-05-2022, 03:22 PM   #7
goodcar
I might be wrong but I think the threads on the jets are metric.
goodcar is offline   Reply With Quote
Old 03-05-2022, 04:12 PM   #8
Bill G
Bill G's Avatar
I don't think a JB Weld fix is going to get it tight enough to not leak and the tip of the jet might not be at the correct height. I vote for getting a new casting.
Old 03-05-2022, 05:10 PM   #9
Oldgearz
LOOK ON EBAY. THEY HAVE A BOTTOM CASTING FOR $49.99. Search "model A zenith carburetor on EBAY".
Oldgearz is offline   Reply With Quote
Old 03-05-2022, 06:40 PM   #10
old ugly
old ugly's Avatar
I have several.
I sent you a pm.
this is the best way to go. i hope this works for you.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 03-05-2022, 07:38 PM   #11
Gene F
Gene F's Avatar
They are, plus they are pipe-thread. I bet some do-gooder taped it.
Get another lower casting.
Old 03-06-2022, 10:05 AM   #12
Joop
Joop's Avatar
Cavalier home
Do you have a Zenith carburetor?
Joop is offline   Reply With Quote
Old 03-06-2022, 10:10 AM   #13
cavalierhome
Originally Posted by Joop View Post
Cavalier home
Yes it's a Holley I think.
Old 03-06-2022, 12:22 PM   #14
Bud
Bud's Avatar
There is an article in the current Restorer magazine for repairing threads in the carburetor casting with Helicoils.
Bud is offline   Reply With Quote
Old 03-06-2022, 12:52 PM   #15
Tom Endy
Tom Endy's Avatar
Some years back I repaired the cap jet threads in a Zenith by applying a coating of JB weld. It worked well. Attached article describes the jets threads used in the Zenith.
Tom Endy
Old 03-10-2022, 09:43 AM   #16
cavalierhome
So I think I found a good way to fix the Jet issue.
I didn't want to go with helicoil because they allow fluid to leak passed the threads I think.
I decided on time-sert
I found out the threads on the Cap jest are 5mm .75 pitch
I was not able to find a time-sert in 5mm .75 pitch, but I could find 5mm .80 pitch, so I figured they are so close I could just chase the time-sert with a .75 pitch tool.
It turns out the jet is pipe tread and works perfectly with the .80 pitch time-sert.
So I threaded the jet location for the time-sert an used an old jet to chase it in.
It seems to be fine, and I hope it works well.
It seems to hold vacuum but it is hard to tell because there are so many ways that passage receives fluid. If it still wants to allow some small amount of fluid over the long term to get passed the threads I will remove the time-sert and reinstall it with some ultra copper RTV. I have used that stuff to fix all kinds of leaks on race cars and it works. But I want to test this without it at first to see
I have the carb ready to go except the secondary well didn't come with the rebuild kit so I have one coming in.
Once I finish that I will try the carb and see if it still leaks gas while parked.
I will let you all know, and if it works I hope this helps somebody else someday.
Old 03-10-2022, 10:04 AM   #17
johnneilson
That sounds good
question though, isn't a 5mm x .8 an IMP 10-32?
I know on machinery I have seen 10-32 and 5mmx.75 interchanged.
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 03-10-2022, 10:38 AM   #18
cavalierhome
Originally Posted by johnneilson View Post
That sounds good
John
Sincerely I don't know but it might be worth finding out.
Old 03-10-2022, 10:43 AM   #19
cavalierhome
Seems o be similar but not exactly the same:
https://www.emuge.com/sites/default/...ill-CardV5.pdf
Old 03-10-2022, 07:38 PM   #20
Brentwood Bob
Latest Restorer has an article on installing inserts.
