I am looking for a clutch Pedal like in the picture below. I Have not been able to identify what it was used on. It does not appear to be 32-48 passenger car but thought it possibly could be pickup. I would appreciate any help. Also would be interested if anyone has a pedal assembly with this clutch pedal they would part with.
Thanks Dan |
Any chance there is a part number cast into it? My guess is that there is an extra bend that didn't come from the factory.
Charlie Stephens |
Charlie,
All I have is that picture. Yes it has been bent to fit that application. I have 33, 34, 35, 36, 38 & 39 pedal assemblies and none have that dog on the bottom of the clutch pedal but, after looking online at 1940 pedal assemblies I'm starting to think that may be a 40 brake pedal that has been used for the clutch pedal. |
Looks like a 39 pedal setup that someone bent. Custom work, frame even has a nice little pocket. or not. Guess you could put and pedal on it.
No its not 39. 39 has the clutch dog on the far right end of the shaft.
they look like modified 40 pedals, in a 33-34 frame.
If I can get out to the garage today, I'll take a look at some '40 and later pedal assemblies and some other loose pedals that have been removed from their mounting brackets. I know I have some pedals that look very similar to the one in your picture.
#11 | |
![]() Quote:
Thanks Dan |
#13 |
I was thinking a 40 brake pedal too. The dog leg of the lower lever is the giveaway. It might be a mercury part. It's been bent so who can tell. It will have a part number on it so that would tell you. You won't get anther one as that is a custom application.
Mart. |
#14 | |
![]() Quote:
I'm looking for a set of 40 pedals and then another 40 brake pedal so I can modify for the same application as shown in the picture. It wasn't until after I started this thread that I figured out that clutch pedal in the picture was really a brake pedal used in place of the clutch pedal. |
#15 |
Not real impressed with cutting down almost through a structural member, the pedal is in the "up" position. Why would you want to recreate it? Or are you just curious?
P.S. You should have pictures of the nuke plant cooling towers displayed! Last edited by deuce_roadster; 01-25-2020 at 11:55 AM. |
#16 |
i think i have a 40 set up thats missing the clutch pedal. send me a pm if that excites you
#17 | |
![]() Quote:
Cooling towers are in the background can't you see them...LOL |
#18 |
That's what I found with my 33. Mine has 39 pedals in it. The X member leg gets seriously compromised. One of the jobs on my backburner to-do list is to rework back to 33 pedals with an hydraulic conversion.
Mart. |
#19 |
shoot! my brain had it backwards, its missing the brake. sorry for the disappointment.
#20 |
This is a fairly common approach to installing hydraulic brakes in the early frames (33/34).
