Old 12-30-2021, 11:25 AM   #1
CJStefan
Default Looking for '49 wheat pennies
Anybody have a pair they want to part with? Time to block those crossover passages. I'll use a different year than '49 but...well, you know
CJStefan is offline   Reply With Quote
Old 12-30-2021, 11:35 AM   #2
19Fordy
19Fordy's Avatar
Default Re: Looking for '49 wheat pennies
If you don't find any wheat pennies, Canadian pennies were 98% copper during these years. I think Canada stopped minting pennies a few years ago.
1982–1996 2.5 g 98% copper, 1.75% tin, 0.25% zinc
1980–1981 2.8 g 98% copper, 1.75% tin, 0.25% zinc
There are 1949 Lincoln wheat pennies on Ebay.
https://www.ebay.com/sch/i.html?_fro...penny&_sacat=0
Old 12-30-2021, 12:37 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
If you are not worried about the engine swallowing the pennies and causing internal damage, by all means use them.
Otherwise all that I have ever done is bend up a thin piece of (tin can) sheet metal that can be slid in to install or removed if not wanted without removing intake.
Old 12-30-2021, 01:01 PM   #4
19Fordy
19Fordy's Avatar
Now there is a very good idea.
Old 12-30-2021, 02:02 PM   #5
Newc
Newc's Avatar
Copper- use a piece of copper plumbing pipe smash it flat, and cut out what you need. two thicknesses available at any store. Newc
Old 12-30-2021, 02:34 PM   #6
51woodie
51woodie's Avatar
I'm sure this question was asked many times, so what is the purpose of blocking off the crossovers? Less heat on the carb?
The pennies in the manifold reminded me of to two dimes under the bridge of my dad's fiddle. When asked why they were there, he would reply, "So I can say I'll never be broke."
51woodie is offline   Reply With Quote
Old 12-30-2021, 03:01 PM   #7
petehoovie
petehoovie's Avatar
Old 12-30-2021, 03:51 PM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
CJ, if you haven't found any '49 wheat back pennies yet, and still want to go that way to block heat riser holes in intake manifold, send me a Fordbarn pm with your name and address, and I'll send you some.
John
Old 12-30-2021, 05:46 PM   #9
RKS.PA
RKS.PA's Avatar
I know the "traditional" way to block off the heat risers was to use pennies corresponding to the year of the car. But, I liked '51 Merc's idea of a piece of sheet metal. I bought two cheap stainless putty knives at Harbor Freight and "sacrificed" the handles. Worked very well, more than covered the holes, and won't get sucked into the engine, being held in place by the intake manifold.
And....I really do like the way she raps through my dual Smithy's !!! (Have acknowledged that at my age, there's no hope of my outgrowing the love of a "modest" sound of power!!!)
RKS.PA is offline   Reply With Quote
Old 12-31-2021, 08:35 AM   #10
36coupe
36coupe's Avatar
Will that interfere with the gasket sealing?
36coupe is offline   Reply With Quote
Old 12-31-2021, 08:51 AM   #11
Bored&Stroked
Bored&Stroked's Avatar
I prefer a thin piece of stainless sheet metal - it won't rust out due to water vapor and other such fun . . .
Old 12-31-2021, 01:20 PM   #12
Russ/40
Russ/40's Avatar
The high zinc pennys were 1982 and after. Use any before then
Old 12-31-2021, 07:33 PM   #13
ford38v8
ford38v8's Avatar
Pennies won’t get sucked up, the holes are exhaust, not intake.
1/8” holes drilled in the Pennies keep the carb warm enough.
I’d also be concerned about vacuum leak by using a stainless shim.
Alan
Old 12-31-2021, 08:47 PM   #14
RalphG
RalphG's Avatar
I must have missed the part explaining why you would want to block those passages. I think cold performance would be better with that crossover working the way it was designed.
RalphG is offline   Reply With Quote
Old 12-31-2021, 10:59 PM   #15
tubman
tubman's Avatar
"RalphG", it sounds like you're one of "those guys" who think the Ford engineers knew what they were doing. I'm one as well.
I don't see why this is necessary except for an all-out race engine. The proper manifolds for those don't have a provision for manifold heat anyway, so why bother?
Old 01-01-2022, 12:53 AM   #16
RalphG
RalphG's Avatar
I would think that hot exhaust air would aid in preventing carburetor icing which can be a real problem here. My 52 Merc still has the heat riser valve in the right hand exhaust manifold.
Old 01-01-2022, 05:26 AM   #17
51 MERC-CT
51 MERC-CT's Avatar
Blocking the heat riser holes with pennies so far as I know never had anything to do with improving or modifying engine performance.
It was a fad that intended to change the exhaust sound that some thought was "cool"
Old 01-01-2022, 09:29 AM   #18
Gene1949
Gene1949's Avatar
Period correct pennies sounds just a bit anal
On a more serious note, as cranky as a flat motor is (timing, carb adjustment, fuel distribution and engine temperature) the very last thing I would do is remove the heat under the carb for a "cool sound".
Gene1949 is offline   Reply With Quote
Old 01-01-2022, 10:18 AM   #19
51 MERC-CT
51 MERC-CT's Avatar
But if you were experiencing 'vapor lock' it may be a step toward reducing the problem.
Old 01-01-2022, 12:10 PM   #20
JT FORD
JT FORD's Avatar
I always used a stripe cut out of a tin beer can. You don,t have to remove the manifold just loosen the bolts, raise one side and then the other side and sllip them in. I all ways removed them in the winter time.........
JT FORD is offline   Reply With Quote
