Old 11-07-2021, 10:54 AM   #1
vern hodgson
Default Coil bad?
I have spark at the points but no spark plug spark, using a test lite batt, side of coil lite shines bright, on other side of coil lite is quite dim. Is coil bad and why no spark at plug?
vern hodgson is offline   Reply With Quote
Old 11-07-2021, 02:26 PM   #2
eagle
eagle's Avatar
Default Re: Coil bad?
When you "pop" the points you should get a nice hot blue spark out of the coil. Open the distributor and use a hand crank to turn over the engine until the points are NOT on a lobe (closed), turn on the ignition, use a wooden popsicle stick or a screwdriver if you are careful and snap the points open/closed. If the points are closed, one side of coil should be battery, other side ground. Clean points.
Old 11-07-2021, 02:33 PM   #3
old ugly
old ugly's Avatar
use the coil wire against the block to see if you have spark.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 11-08-2021, 10:21 AM   #4
Will N
Will N's Avatar
You should have the same voltage at either low tension post of the coil. Your test with the light is telling. I suspect that the primary winding is grounding out inside the coil. Check if you get a reading with your test light from one post of the coil to the metal case, which would show that a short has occurred.
Will N is offline   Reply With Quote
Old 11-08-2021, 06:04 PM   #5
1crosscut
1crosscut's Avatar
Like Eagle said snap the points while holding the end of the coil wire a short distance away from a head nut to check for a nice blue spark. If you have a good spark there then check the condition of the caps graphite button contact to see if it is worn down. Then check the condition of the rotor.
I just had the same trouble today with a club members Roadster. The rivet holding the spring steel that contacts the button on the cap to the fixed contact on the rotor was loose. Replaced the rotor and all is now good.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 11-08-2021, 08:07 PM   #6
vern hodgson
Ok, on the agenda for tomorrow, may have found the problem, I will organize the wiring so it is not a jumbled rats nest but I had coil wire going thru a 90degree boot and that may have prevented the coil wire from going in far enough to make contact.
Old 11-08-2021, 09:50 PM   #7
Gary WA
Gary WA's Avatar
I know what it is now! your pet rats nest. Good Luck Vern!
www.whidbeymodelaclub.com
Old 11-08-2021, 11:57 PM   #8
vern hodgson
Wiz hopin y,all would come and dis-entangle it
Old 11-09-2021, 07:30 PM   #9
vern hodgson
Put the coil wire to the block, got a very weak spark. Weak coil?
Old 11-09-2021, 10:08 PM   #10
Flathead
Flathead's Avatar
Yeah, try a different coil.
Flathead is offline   Reply With Quote
Old 11-10-2021, 07:17 AM   #11
Big hammer
Clean the coil wire socket, and the wire ends! I had a boot on the wire that goes into the coil, out of sight out of mind.
get a bigger hammer tap done
Old 11-10-2021, 11:33 AM   #12
katy
katy's Avatar
Are you sure that it's a 6V coil? Not 12V? Primary side resistance should be~1.5 ohms.
Old 11-10-2021, 11:50 AM   #13
eagle
eagle's Avatar
Do not replace anything until you have verified its fault. What is the voltage on each side of the coil when the points are closed? Should be battery on one side, very near ground on the other. I think you'll find its not being grounded properly through the point/switch circuit. Clean and set point clearance.
