Old 11-06-2021, 04:39 PM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Turn Signal Flasher 12V
This post is a point of information.
After a lot of iterations to discover why the turn signal indicator lamp was rarely working, I narrowed the problem down to the thermal type flasher. I replaced it with a Novita EL13 12v 3-prong unit and the indicator lights work consistently with an audible clinking noise. The EL13 Flasher is semi-transparent, so you can see what's going on inside of it.
The local auto parts store charged $16.28 for one. If you opt for this flasher, make sure its spec indicates it works with a mixture of LED and Incandescent bulbs.
My Victoria has Bratton's main wiring harness with an integral signal system that uses 2 LED tail lights and incandescent bulbs in the cowl lights.
Bob Bidonde
Old 11-07-2021, 08:08 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Turn Signal Flasher 12V
Nice, looks like a good replacement for the 550. Good info.
But, I can't find one similar in 6v. [ 535 ]
Old 11-07-2021, 10:40 AM   #3
katy
katy's Avatar
My '31 CCPU (+ ground) uses a 6V electronic flasher with built in beeper, works good.
Old 11-07-2021, 01:56 PM   #4
Ruth
Bob, is this a thermal flasher? I see it is on Amazon.com for $10.54.
Ruth
Old 11-08-2021, 09:22 AM   #5
Badpuppy
Novita has been making e-flashers for several years, but only 12V. Little market for 6V positive ground. Tridon has one of the same number.
Old 11-08-2021, 09:31 AM   #6
Certimafied
Certimafied's Avatar
Lmctruck has a 6v flasher, I think it is a thermal and is three pronged. heres the part number I found 47-0730-C
Certimafied is offline   Reply With Quote
Old 11-08-2021, 09:54 AM   #7
Bob Bidonde
Ruth, it is a thermal flasher.
Bob Bidonde
Old 11-08-2021, 12:07 PM   #8
CarlG
CarlG's Avatar
Probably wouldn't work with all LEDs
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-08-2021, 01:14 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
Bob, Good to know. I have had it with electronic flashers They don't last.
Old 11-08-2021, 03:29 PM   #10
Patrick L.
Patrick L.'s Avatar
Last paragraph of post #1.
Old 11-08-2021, 08:07 PM   #11
CarlG
CarlG's Avatar
The Electronic Flasher I have is now several years old and is still working fine. Only thing I don't like about it is that it is totally silent -- no clicking at all. (It only comes 12v Neg ground).
Alaskan A's
Old 11-08-2021, 11:58 PM   #12
Y-Blockhead
That is the exact FL-3 flasher that just burned out after ~5 months, for the second time... one of the reasons I went with a back to a thermal flasher.
I am glad the FL-3 worked out for you. It did work good when it was working, but they don't last for me.
Old 11-09-2021, 11:08 AM   #13
katy
katy's Avatar
Could be RFI or some other electrical noise in your car's system that is causing the electronics to fail.
Old 11-09-2021, 02:14 PM   #14
Y-Blockhead
I'm sure you're correct but after three electronic flasher in the last year I went back to a thermal flasher with amber incandescent bulbs in front and LEDs in back. No problems... yet.
Old 11-10-2021, 01:26 PM   #15
5lugnuts
Positive ground, works with LED or/and incandescent. six to 24 volt.
https://www.ledlight.com/led-flashers.aspx
Explore the site for other interesting stuff.
5lugnuts is offline   Reply With Quote
Old 11-10-2021, 05:02 PM   #16
Patrick L.
Patrick L.'s Avatar
The very first one listed, does not work. #84787
Old 11-10-2021, 06:00 PM   #17
jmkelbaugh
We are having issues with getting the turn signals to work. Have a two prong. Installed LED rear lights with incandescent headlights. Signals didn’t work before the install of LEDs. Using thermal actuator Novita EL12. Recently bought vehicle and are new to this stuff.
jmkelbaugh is offline   Reply With Quote
Old 11-10-2021, 06:51 PM   #18
Patrick L.
Patrick L.'s Avatar
We need quite a bit more info.
Old 11-10-2021, 10:31 PM   #19
30Murray
You may find that when you convert to LED taillights, they don't draw enough current to make a thermal flasher work. The simple fix is to add a load resistor to each circuit. Simply t-tap and run to ground. You can get them from Model A vendors or Amazon.
30Murray is offline   Reply With Quote
Old 11-12-2021, 04:03 PM   #20
5lugnuts
"The very first one listed, does not work. #84787"
Mine works with incandescent on cowl and LED in the rear. I ran a new power wire to the flasher, then to the Signalstat. I will change that by tapping into the power wire that goes to the stop switch and eliminate the extra wire I added.
"Positive ground, works with LED or/and incandescent. six to 24 volts.
https://www.ledlight.com/led-flashers.aspx"
"Flasher LED 6 Volt Positive Ground 3 Terminal for 6 Volt positive chassis. LED flasher for vintage and classic cars and motorcycles. This flasher is LED compatible so you can use led's or incandescent bulbs or a combination of both. The flasher creates real clicking sounds like an old flasher. The flasher duty cycle is from 30% to 70%. The flasher rated load can handle up to 6 bulbs or 120 watts."
