Old 10-09-2023, 01:49 PM   #1
rust revival
Default Double post please remove
rust revival is offline   Reply With Quote
Old 10-09-2023, 02:28 PM   #2
California Travieso
Send a message via Yahoo to California Travieso
Default Re: 28-29 cowl post stanchions inside bracket
You didn’t mention the model of your car. The only one I’m aware of making reproduction parts is Brookville but they only make them for open cars, e.g., roadsters and roadster pickups. Not sure if that part would fit other cars. You might have to check out the swap meets or online.
David Serrano
California Travieso is offline   Reply With Quote
Old 10-09-2023, 02:42 PM   #3
Bob C
Is this what you are looking for? https://www.snydersantiqueauto.com/p...4469&cat=41631
Old 10-09-2023, 03:27 PM   #4
rotorwrench
rotorwrench's Avatar
Those are on all the 28/29 Phaetons and open cab pickups as well. Brookville manufactures all the sheet metal for model A roadsters and open cab pickups. Phaetons only share the cowl & front doors on four door types.
Old 10-09-2023, 04:09 PM   #5
rust revival
Sorry 28-29 Roadster ,my cowl post is perfect just missing that inside bracket,and when I click on the Brookville picture it just shows the whole post ,but looking at it it doesn't even show the part I need attached to the post? Are they just using nuts ?
Old 10-09-2023, 04:30 PM   #6
jwmckenzie
I would call Brookville and see if they would supply just the part you need. May not be in the catalogue, but they have to make them so maybe.......
jwmckenzie is online now   Reply With Quote
Old 10-09-2023, 09:02 PM   #7
Bob C
Vintage Ford list Windshields Post Stancion Backing Plates 1928-29 but
they don't show a picture. https://www.vintageford.com/global_s...54-6&Category=
Old 10-09-2023, 09:12 PM   #8
rust revival
Thanks everyone. Definitely appreciate your help and time , I'm going to follow up with vintageford and see if I can get a photo
Old 10-11-2023, 04:07 PM   #9
rotorwrench
The model A parts sources stock a lot of Brookville pieces but finding them in their respective search systems can be a challenge. The paper catalogs were easier to use. Nomenclature for some parts differs and sometimes the parts aren't pared well with associated assemblies for search attempts. It can make for a long search with no good final outcome sometimes.
