Old 09-25-2021, 06:27 PM   #1
fredeuce
fredeuce's Avatar
Default 8BA Distributor Setup
I have just reassembled the distributor for the 8BA I am rebuilding and performed a trial fit to the timing cover. See the picture attached.
My concern is that the distributor appears to travel too far into the housing and not properly meshing with the drive gear once assembled.
Am I observing a problem that doesn't really exist?
I would be grateful for any tips on this installation.
fredeuce is offline   Reply With Quote
Old 09-25-2021, 06:28 PM   #2
alanwoodieman
Default Re: 8BA Distributor Setup
when attached to the head this will not happen
Old 09-25-2021, 06:32 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
As stated the head mounting surface determines how deep the distributor goes.
Old 09-25-2021, 06:37 PM   #4
fredeuce
fredeuce's Avatar
Thanks for the clarification. This is my first time assembling one of these that was dis-assembled by someone else so flying a bit blind at the moment. Thanks again.
Old 09-25-2021, 11:06 PM   #5
mercman from oz
mercman from oz's Avatar
8BA Distributor Set-up
Old 09-26-2021, 10:11 AM   #6
19Fordy
19Fordy's Avatar
fred: Be sure to read these threads about distributors and timing covers:
https://www.fordbarn.com/forum/showthread.php?t=177248
and
https://www.google.com/search?q=8ba+...hrome&ie=UTF-8
19Fordy is online now   Reply With Quote
Old 09-26-2021, 04:46 PM   #7
fredeuce
fredeuce's Avatar
19Fordy,
Thanks for that . I had no idea there were such variations with the distributors and timing covers.
Fred
Old 09-27-2021, 11:15 AM   #8
19Fordy
19Fordy's Avatar
Originally Posted by fredeuce View Post
19Fordy,
Fred
Just one more thought. If you still have the stock passenger side head installed on the engine, measure the height from the surface of the block to the top of the tab that the distributor rests on. Write that number down and keep it with your engine data. That way you will always know that measurement should you decide to install another disttributor or change heads to the earlier "center hose" style. Take photos also.
For instance, when I installed early heads on my 8BA I found I needed to make a 1/4 in. thick spacer for the Mallory distributor to make it "mesh" properly.
Old 09-27-2021, 05:34 PM   #9
fredeuce
fredeuce's Avatar
19Fordy, What you suggest had crossed my mind after the first posts about the distributor resting on the RHS head. As this engine was in pieces when I received it there was no chance of doing that. However the original heads have been milled to take out some warpage. The machinist said he took off 0.030" . That being so I am thinking of setting up the distributor drive gear to mesh properly then place a clamp around the distributor body to hold it at the correct depth and then check to see what clearance exists between the distributor and the head when I install it that should show the thickness of any spacer needed.
Old 09-27-2021, 06:04 PM   #10
19Fordy
19Fordy's Avatar
Sounds sensible. Good luck, Jim
Old 09-27-2021, 10:44 PM   #11
51 MERC-CT
51 MERC-CT's Avatar
Sounds like you are over thinking this, the distributor gear will mesh with the cam gear the same way all along the length of the distributor gear.
It does not have to be centered.
Old 09-28-2021, 08:37 AM   #12
19Fordy
19Fordy's Avatar
Here's an interesting discussion about distributor gear mesh.
https://www.thirdgen.org/forums/tech...you-check.html
If you GOGGLE "how do distributor gears mesh" more info. appears.
