Old 10-09-2021, 10:42 AM   #1
joe 1950
joe 1950's Avatar
Default out side dr handle 35 pick up
A very good friend of mine has a 1935 ford pk up i helped him restore @ ten years ago since then both outside door handles come out of the bezel that bolts to the door when opening i know we’re going to have to take the door panels off to see what’s broke but would like to get a heads up to pre order parts can’t seam to find a good pic of the pieces involved with holding the handle from any parts catalogs in no hurry this will be a winter project
joe 1950 is offline   Reply With Quote
Old 10-09-2021, 02:57 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: out side dr handle 35 pick up
There should be no need to remove door panels unless parts have fallen inside.
Remove the fasteners holding the bezel to the door.
There is a washer with a square hole that slides on to the handle shaft to a point where it is staked to the shaft to keep the bezel secured to the shaft.
If a way can be devised to re-secure the washer, that should fix it, otherwise new handles are in order.
The original bezel is sheet metal (not cast) and the spring is just a rattle reducer.
Old 10-10-2021, 01:40 AM   #3
deuce lover
deuce lover's Avatar
Here are pics of the repop which shows how its put together.Between the cup and inside of the escutcheon is a spring. Might be that the spring is shot ? The cup is secured by the shank being swedged.Small cotter pin works also .
Old 10-10-2021, 04:39 AM   #4
mercman from oz
mercman from oz's Avatar
Reproduction out side door handle for 1935 Ford Pick-up - photo by deuce lover
Old 10-10-2021, 11:01 AM   #5
joe 1950
joe 1950's Avatar
Thanks for the heads up i can clearly see how that’s put together will start there first easier than pulling panels
