Old 08-24-2021, 12:44 PM   #1
RalphM
RalphM's Avatar
Default Source for 47 lower front shock studs??
Converting to 47 over to airplane shocks, I already have the 1948 style upper mounts. I’m looking for the stud that goes in where the original shock would have, but will fit the modern shocks. Does anybody sell these?
Picture shows where they go, the little Mickey Mouse ears right above the axle. One side holds sway bar, other holds shock.
File Type: jpeg A524BC7F-3C3B-49C1-B7A3-D7A21D3F2314.jpeg (137.2 KB, 56 views)
RalphM is offline   Reply With Quote
Old 08-24-2021, 01:02 PM   #2
RalphM
RalphM's Avatar
Default Re: Source for 47 lower front shock studs??
Like this
File Type: jpeg 6A3EEDF0-0003-4DBA-B2FA-611BE69614BC.jpeg (84.7 KB, 4 views)
Old 08-24-2021, 01:13 PM   #3
Ggmac
I think I purchased mine from speedway. It may have been in the racers catalog for some reason . Ill see if I can find the part numbers
Old 08-24-2021, 05:30 PM   #4
RalphM
RalphM's Avatar
Thanks, yeah I’ve seen where people will just drill a hole through the axle and put a standard shock mount in but I didn’t want to do that unless I have to.
Old 08-24-2021, 06:39 PM   #5
rich b
rich b's Avatar
Looks like your front end is out in the picture; why not get a '48 axle with the hole for a shock stud; not like they are rare or in high demand.
The '48 frame mounts are also set for a shock located in front of the axle; also locates the shocks at a better angle as compared as hooking them above perch bolt does.
rich b is online now   Reply With Quote
Old 08-24-2021, 07:00 PM   #6
mercman from oz
mercman from oz's Avatar
Larger picture of Ralph's 1947 Ford Front-end in question.
Old 08-24-2021, 07:01 PM   #7
Lawson Cox
Lawson Cox's Avatar
Go to Joe's Auto parts. He sells the conversion kit, maybe he will sell you the studs only.
Old 08-24-2021, 07:58 PM   #8
RalphM
RalphM's Avatar
Well originally it had a 48 axle in it with the holes in the axle for the shock mounts. But that axle was bent and I found this one to replace it with.
Yes I’ve seen the kits at Joe’s, he uses homemade perch pin that looks similar to the ones I have. Thanks, maybe I’ll give them a call.
