Old 08-02-2021, 08:59 PM   #1
Ford coupe
Angry electric 6 volt pump
the 6 volt pump on my 55 will not let enough fuel through when driving with it off for the car to run proper ..Have to turn on the electic every once in a while..Is there a better pump out there???
Ford coupe is offline   Reply With Quote
Old 08-03-2021, 06:02 AM   #2
KULTULZ
KULTULZ's Avatar
Post Re: electric 6 volt pump
You need to source a pump with a flow-thru rating if only used as a primer or dual circuit the system.
INFO - http://www.how-to-build-hotrods.com/...fuel-pump.html
Example of FUEL PUMP SAFETY INERTIA SWITCH -
- https://www.fordonlyparts.com/1994-1...nertia-safety/
One example of pump mounting noise isolaters -
https://www.summitracing.com/parts/CRT-18-14U
File Type: jpg FUEL PUMP - ELECT Primer On By-Pass Circuit.jpg (51.7 KB, 15 views)
KULTULZ is offline   Reply With Quote
