Old 07-26-2021, 02:40 PM   #1
Royal Ryser
Default How much is 6 volts?
Actually, what should the voltage be for a fully charged 6 volt battery? Any difference between an Optima and a regular lead-acid battery?
Royal Ryser is offline   Reply With Quote
Old 07-26-2021, 02:55 PM   #2
rockfla
rockfla's Avatar
Default Re: How much is 6 volts?
Most of my lead acid 6V have been in the 6.29 to 6.35 Volts by my VO meter
Old 07-26-2021, 02:55 PM   #3
Lawson Cox
Lawson Cox's Avatar
Optima costs more but lasts three times as long with no corrosion. Oh, 6V.
Old 07-26-2021, 03:35 PM   #4
slowforty
slowforty's Avatar
I got an Optima from Amazon and they gave me $150 off if I got their credit card which I will probably never use
slowforty is online now   Reply With Quote
Old 07-26-2021, 03:36 PM   #5
Kube
Kube's Avatar
To answer the question asked, right around 6.3v fully charged. Optima or acid, it's still right about 6.3v.
Old 07-26-2021, 03:41 PM   #6
rockfla
rockfla's Avatar
I thought I did answer the question?
Old 07-26-2021, 03:53 PM   #7
Kube
Kube's Avatar
You did. As did I.
Old 07-26-2021, 04:03 PM   #8
DavidG
DavidG's Avatar
Now, now, boys, let's not forget that it's a hobby.
DavidG is online now   Reply With Quote
Old 07-26-2021, 04:05 PM   #9
JSeery
JSeery's Avatar
There are battery state of charge charts that can give you an idea of what the battery charge is.
Old 07-26-2021, 05:21 PM   #10
cadillac512
cadillac512's Avatar
Typical conventional lead-acid batteries are approximately 2.1 volts per cell...and provide the voltages that the esteemed gentlemen above referenced.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 07-26-2021, 06:42 PM   #11
rockfla
rockfla's Avatar
Originally Posted by Kube View Post
You did. As did I.
NO hard feelings or Ill intent, just trying to be an “Ellic Smart”!!! Sorry Kube & DavidG!!! MY BAD!!!
Old 07-26-2021, 06:48 PM   #12
VeryTangled
VeryTangled's Avatar
Auto batteries are 2.1V per cell @ 100% charge.
-Jeff H
Old 07-26-2021, 08:36 PM   #13
tubman
tubman's Avatar
BTW, Optima's are still lead-acid batteries; they just do it differently using AGM (Absorbent Glass Mat) technology.
Old 07-26-2021, 08:56 PM   #14
Tinker
Tinker's Avatar
And optimas do not like to be topped off every sitting day. Same with cell phone batteries. You can over cycle them. if you leave them plugged in all time. It's okay to let them run down. If your charging system is decent you don't need to tend them, never have. You don't need to leave your garage everytime with a "fully" charged battery. Optima batteries going on 10 and 14 yrs now.
Old 07-27-2021, 08:27 AM   #15
Royal Ryser
Thanks for the help, guys. I asked this question on the Barn because I knew I'd get a quick, accurate answer, and maybe some humor? too.
Old 07-27-2021, 08:39 AM   #16
rockfla
rockfla's Avatar
All be it "Sarcastic" hopefully NOT obnoxious!!
Old 07-27-2021, 01:39 PM   #17
Crankster
Crankster's Avatar
Yes, there is. I always recommend reading primary sources, in this case, why not find out what Optima says?
https://www.optimabatteries.com/expe...attery-voltage!
In the 12 volt universe there is some misunderstanding on what a "fully charged" battery will measure, because battery chemistry and materials have changed a fair bit over the years. Now it is true most people will not care a whit, just so long as there is enough juice to start the car. But for the nerds, the ODC types, the numbers vary.
"Modern" maintenance-free sealed car batteries - invented in 1971 btw - have a different open circuit voltage when fully charged than a "standard lead-acid" battery. (The kind with filler caps to add distilled water) The latter when fully charged, measure 12.65 volts at 77° F; maintenance free and AGM on the other hand, will measure 12.80 volts.
A tenth or two of a volt doesn't sound like much, but as a percentage of battery charge it looms large, especially over a period of time, because of what's called permanent sulfation. Batteries are getting expensive to buy now. They tend to last much longer, and give better service, when preventive maintenance is followed. So, an OPTIMA 6V battery depending on which flavor you buy, is going to measure about 6.4 volts (or more).
I know one of the selling points of the OPTIMA is they laugh at neglect, but I can't help but wonder if they would last even longer with a little TLC now and then? Maybe.
It's also important to pay attention when choosing a battery charger, there are GEL cells, AGM, spiral wound, as well as "deep cycle" or marine batteries available, it's not just the good ole lead-acid automotive start batteries around anymore. They all have slightly different charging profiles and/or discharge characteristics. When spending bigger bucks on these fancy pants boutique battery, I'd especially want to make sure it gets charged "just right", not too much, not too little.
Some people suggest a strategy of buying a really good, high quality battery charger, coupled with a more middling quality battery, versus an equivalent amount of money spent on the "best" warranty and high CCA battery alone.
Crankster is offline   Reply With Quote
