Old 07-21-2021, 09:50 AM   #1
cowtown
Default 1929 closed cab mounting blocks
I'am putting together a 29 CCPU and need some pictures of how and where the rear and middle wooden mounting blocks go. Does anyone have any pictures and tips of how the cab should be mounted. I have the blocks and bolt kit to do the job. This is a rusty cab and bed that I have gathered up here in Montana and were not on a chassis. I am not going to paint the truck but going to just keep it to look like a barn find. I have already installed a new wood kit in the cab, Wooden top kit and Also new metal floor seat pan and risor. I have the cab sitting on the frame and the bed and fenders mounted. Thanks Ford Barn!
cowtown is offline   Reply With Quote
Old 07-21-2021, 10:55 AM   #2
LeonardS
Default Re: 1929 closed cab mounting blocks
Deleted
LeonardS is offline   Reply With Quote
Old 07-21-2021, 12:09 PM   #3
Dan Partain
Dan Partain's Avatar
Here are some additional photos. There is a piece of rubber that tacks to the block. The rubber is between the frame and the block. My photo shows a flat washer but there is only a nut and lockwasher used for the body bolts. This was taken while I was lining up the cab and shimming to get the doors and body adjusted, I don't use the lock washers while I'm doing that adjustment.
Dan Partain is offline   Reply With Quote
Old 07-21-2021, 12:35 PM   #4
Brentwood Bob
Rubber looks similiar to belting.
Brentwood Bob is offline   Reply With Quote
Old 07-21-2021, 02:06 PM   #5
Papa's CCPU
Papa's CCPU's Avatar
Originally Posted by LeonardS View Post
I happen to have my 28 CCPU on the lift
FWIW, It looks as though your using the AA bolt location on your cab, and your frame was for a car, as it is not drilled for CCPU mounting...
Check this link for details on 82-A cabs from Neil Wilson
click link for AA-82205 d3 Floor Pan
https://aafords.com/cabs/82-a-closed...d-cab-details/
https://aafords.com/wp-content/uploa...2205-d3-q8.jpg
Cowtown, I had to drill my frame as well, mounted cab and lined everything up to mark hole locations...
Papa's CCPU is offline   Reply With Quote
Old 07-21-2021, 02:40 PM   #6
LeonardS
Who knows what has happened to it in the last 90+ years. I didn’t buy it new…..🤓
Old 07-21-2021, 03:00 PM   #7
Papa's CCPU
LeonardS,
Sorry - Didn't mean for you to delete your post, really meant to help anyone who might have similar situation....
Your pic was an excellent example of what's happened over 90+ years!
Old 07-21-2021, 03:11 PM   #8
LeonardS
LeonardS,
I didn’t want to steer anyone wrong.
Old 07-21-2021, 08:09 PM   #9
cowtown
So does the middle wood block and bolts go in the CENTER BODY BOLT HOLES in the Diagram?
Old 07-21-2021, 10:32 PM   #10
Dan Partain
Yes, those holes are just behind the front piece of the seat riser, under the seat. They will match the holes in the frame.
