Old 02-25-2024, 10:36 PM   #1
Alberta50fordor
Alberta50fordor's Avatar
Default 51 woodie speedometer cable
Has anyone had any issues with speedometer cables with the 49-51 wagons? it was missing in the woodie so i ordered one from shoebox central -A9A-17260 they only list the one and they didn't specify it not fitting the wagons, it seems its almost a foot too short
Alberta50fordor is offline   Reply With Quote
Old 02-25-2024, 11:27 PM   #2
tubman
tubman's Avatar
Default Re: 51 woodie speedometer cable
When I think about it, I don't see why a station wagon would have a different length speedometer cable than any other body style. Are you sure you have it routed correctly?
Old 02-26-2024, 10:46 AM   #3
Alberta50fordor
I still need to get back underneath the car and double check but from what i remember I had it routed the same as my sedan, i even tried going under the air duct in the engine bay
i haven't compared the two cars yet but is the cowl on the wagon deeper than the cars?
Old 02-26-2024, 11:05 AM   #4
tubman
tubman's Avatar
I may be wrong here. After thinking about it, I seem to remember that the '51 woodie may have a different dash than the passenger cars. If so, it's a whole new ball game. Sorry for popping of when I shouldn't.
Edit : I did a little research, and Rock Auto lists a "Trim to Fit" Dorman cable that's 113" long.
Old 02-26-2024, 11:18 AM   #5
51504bat
51504bat's Avatar
Ask Rusty at Speedometer Service in Colorado Springs
https://www.speedoservice.com/
51504bat is online now   Reply With Quote
Old 02-26-2024, 12:31 PM   #6
Bob C
I looked in the parts book and it shows A9A-17260 STD & OD trans
70 3/4" B1A-17260-A auto trans 80 3/4".
Old 02-26-2024, 07:50 PM   #7
Alberta50fordor
Don’t be sorry lol, any help is appreciated
Old 02-26-2024, 08:56 PM   #8
wga
wga's Avatar
Local speedo shop made a new cable for my stock 49 wagon.
Should be the same length as the sedan - cowl is in the same location. Front clips interchange.
Did it coil during install?
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 02-26-2024, 09:14 PM   #9
Krylon32
Another vote for Rusty.
Krylon32 is offline   Reply With Quote
Old 03-01-2024, 08:27 PM   #10
jplutz
jplutz's Avatar
Greetings,
I also had to replace my cable(the housing was present but the cable was missing). Are they supposed to be greased, or is that only needed by the gear on the trans? My friend says the whole housing requires grease. Is that true? And if so, how do you do it? JPL
jplutz is offline   Reply With Quote
Old 03-01-2024, 08:46 PM   #11
paul2748
paul2748's Avatar
Yes - the whole thing need lubrication. There are specialty greases out there but something like white lithium grease should do it. I have used AGS KABLE-Ease Cable Lubricant that I got from Amazon which seems too work ok.
Originally Posted by jplutz View Post
Greetings,
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-01-2024, 09:03 PM   #12
jplutz
jplutz's Avatar
Thanks, JPL
Old 03-03-2024, 10:03 PM   #13
jplutz
jplutz's Avatar
So the my next question is do they come pregreased? If not, do I, or we have to remove the cable from the housing and force grease thru till it comes out the other end, or is there a tool for this? JPL
(I m trying to not have to uninstall the cable if possible)
Old 03-03-2024, 10:49 PM   #14
tubman
tubman's Avatar
DO NOT use grease on the speedometer cable. It will attract dirt and gum everything up. There is special speedometer cable lube, which I believe is a combination of graphite and light oil.
I do not understand your hesitancy in "uninstalling" the cable; I have never had a problem pulling the cable out of the housing and getting it back in. It may take a couple of "stabs" and some rotation, but it should go right back in. It will also give you a chance to clean any previous crud off the cable.
