Old 02-27-2011, 11:48 PM   #1
Scott H
Scott H's Avatar
Default My Rear End is Dirty
36 pickup, I don't think it's moved under it's own power for several decades. The gear lube has turned to a thick syrup, and at the bottom it has solidified to the point where I need to use chisel, ice pick, brass brush and loads of aerosol brake cleaner to make any progress.
"Before" pictures:P2260011 (640x480).jpg
36 1/2 ton pickup
on 38 car frame
with 1940 v8 24 stud
Scott H is offline   Reply With Quote
Old 02-27-2011, 11:50 PM   #2
Scott H
Scott H's Avatar
Default Re: My Rear End is Dirty
"After" pictures:
When I started I had to use a channel locks to turn the driveshaft. Now I can turn it easily with just my fingers.
36 1/2 ton pickup
on 38 car frame
Old 02-27-2011, 11:51 PM   #3
Scott H
Scott H's Avatar
And one of the bells, cleaned and painted and ready to go back in (once I drive in the new axle seal) :
36 1/2 ton pickup
on 38 car frame
Old 02-28-2011, 12:11 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Scott, are you putting a '37-'40/'41 rear in your '36 pu? Just wondering since the axel housing shown is not '36.
John
Old 02-28-2011, 12:18 AM   #5
Scott H
Scott H's Avatar
Yeah, good catch. I'm using the entire chassis from a 38 passenger car. It is in so much better shape than the frame and suspension that is currently under my pickup. I'll use the 36 style gas tank so I won't have issues with the filler tube. The passenger car mounting brackets are already off the frame.
36 1/2 ton pickup
on 38 car frame
Old 02-28-2011, 12:22 AM   #6
Scott H
Scott H's Avatar
The rear leaf spring is already rebuilt and ready to go back in, along with all the original cleaned-up hardware.
36 1/2 ton pickup
on 38 car frame
