Old 05-27-2021, 10:29 PM   #1
mgambuzza
mgambuzza's Avatar
Default Wandering Pheasant
I've noticed lately that my Quail wanders. I start with it tightened, and as I drive, the top piece starts to drift counterclockwise until it pops open. There doesn't seem to be much friction holding it when its supposed to be in the "locked" position. Was wondering if others experienced this (this is a repro Quail radiator ornament). Pictures show in locked, then unlocked position and does so gradually as I'm driving - it is now moving smoothly and with little effort unlatches.
mgambuzza is offline   Reply With Quote
Old 05-27-2021, 10:34 PM   #2
eagle
eagle's Avatar
Default Re: Wandering Pheasant
Flying quail. Mine latches firmly, have to hold it tight to loosen/tighten. You could try a thicker gasket.
Old 05-28-2021, 06:30 AM   #3
nkaminar
nkaminar's Avatar
Add a second gasket.
Old 05-28-2021, 07:23 AM   #4
Mulletwagon
Mulletwagon's Avatar
Check Ace Hardware for a thicker seal/O ring and glue it in place. Been there.
Mulletwagon is offline   Reply With Quote
Old 05-28-2021, 08:44 AM   #5
Big hammer
Righty tighty....lefty lossy.....this would have been a good place for left handed threads....I know no threads
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 05-28-2021, 09:08 AM   #6
Y-Blockhead
Y-Blockhead's Avatar
Easy fix. Snyder's has a rubber "O" ring that makes it a little tighter and seals better than the hard gasket.. Also the brass ring that that goes in the gas gauge fits under the "O" ring to make it even slightly more tighter.
https://www.snydersantiqueauto.com/P...L-THERMO-28-29
https://www.snydersantiqueauto.com/P...earchByKeyword
Old 05-28-2021, 09:24 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
No need to spend any money to fix your quail. Make your own gaskets / shims. If you make its lockup fit too tight, the ears in the lower part of the cap will crack-off. Keep in mind the cap is made of pot metal (AKA ZAMAC).
Bob Bidonde
Old 05-28-2021, 09:39 AM   #8
Jack Shaft
Ford nailed the cars characteristics with the quail ornament...ever flush quail? quick like a shot..
Old 05-28-2021, 02:21 PM   #9
1931 flamingo
1931 flamingo's Avatar
Slow down........................................
Paul in CT
Old 05-28-2021, 06:06 PM   #10
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Originally Posted by y-blockhead View Post
easy fix. Snyder's has a rubber "o" ring that makes it a little tighter and seals better than the hard gasket.. Also the brass ring that that goes in the gas gauge fits under the "o" ring to make it even slightly more tighter.
https://www.snydersantiqueauto.com/p...l-thermo-28-29
https://www.snydersantiqueauto.com/p...earchbykeyword
x 2
Ivan in southeast va. is offline   Reply With Quote
Old 05-29-2021, 10:51 AM   #11
DBrer
I just changed the 0 ring as mentioned, and it cured my quail from wondering.
DBrer is offline   Reply With Quote
Old 05-29-2021, 11:09 AM   #12
katy
katy's Avatar
Paul in CT
The old Mexican told me: "Slow down and get finished sooner", he was right.
