Old 05-17-2021, 02:21 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default '32 style gas tank on a Model A
I recently saw a '32 style gas tank on a Model A. It had a nice sheet metal cover that blended it in and made it appear to be original. Is there a source for these?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 05-17-2021, 03:54 PM   #2
California Travieso
Send a message via Yahoo to California Travieso
Default Re: '32 style gas tank on a Model A
Speedway has a 32 gas tank for a Model A. I believe Brookville has one in their catalog but I’m not sure they have it on their online store, you may have to call. There is an outfit in Oregon that has a 32 gas tank for a Model A but I have to check my files.
I would check with So Cal Speed shop and other hot rod shops in Southern Cal. too.
I think it’s a cool alternative to the old rusty Model A gas tanks. I’m thinking of using it on my 30 Roadster project.
David Serrano
California Travieso is offline   Reply With Quote
Old 05-17-2021, 11:10 PM   #3
Chris Haynes
I heard that So Cal is out of business
1921 Runabout
1930 Tudor
Early 1930 AA
Old 05-17-2021, 11:17 PM   #4
Charlie Stephens
Try posting on HAMB, https://www.jalopyjournal.com/forum/...ssage-board.5/.
Charlie Stephens
Old 05-18-2021, 01:19 AM   #5
Pete
A standard 16 gallon racing fuel cell will fit under the back of a model A and you can't see it if you have a trunk. There is provision for a gauge also.
If you want to see how it is done, come look at mine.
Old 05-18-2021, 08:05 AM   #6
Pat/Ohio
Pat/Ohio's Avatar
You will find the rear frame extensions and '32 Ford gas tank and Tanks, Inc.
https://www.tanksinc.com/index.cfm/p...rod/prd109.htm
Good luck, Pat
Pat/Ohio is offline   Reply With Quote
Old 05-18-2021, 08:54 AM   #7
Lefthander1930
Lefthander1930's Avatar
With the 32 gas tank style in the rear Whats going to get the gas to the motor ??
Gravity. ???
Lefthander1930 is offline   Reply With Quote
Old 05-18-2021, 09:00 AM   #8
Ruth
Gravity. ???
Fuel pump.
Ruth
Old 05-18-2021, 10:10 AM   #9
Lefthander1930
Fuel pump will over power the float since the carb is meant for gravity feed .
Old 05-18-2021, 10:22 AM   #10
Bob C
Kind of reminds me of the Pinto.
Old 05-18-2021, 10:24 AM   #11
Bruce of MN
Bruce of MN's Avatar
Pressure regulators are available.
Old 05-18-2021, 10:44 AM   #12
nkaminar
nkaminar's Avatar
I can see some advantages and disadvantages in doing this. First, I would not do it with my present car because I want to keep it fairly original. But it would open up the cowl area on a Model A for all kinds of things, like a radio, or an air conditioning evaporator and fan. The 32 tank needs to be protected in case of a rear end crash, maybe converting it over to a fuel cell if that is possible. I already have a fuel pump for my Weber so that would not be an issue.
Old 05-18-2021, 10:48 AM   #13
katy
katy's Avatar
It would be a good add-on for touring in remote areas. W/2 tanks one can get twice as far from the nearest gas station.
Old 05-18-2021, 10:56 AM   #14
Charlie Stephens
That is why they make pressure regulators.
Charlie Stephens
Old 05-18-2021, 02:04 PM   #15
California Travieso
So Cal Speed Shop is back in business: https://www.est1946.com/about-us.aspx
There also a good article in Hot Rod Magazine: https://www.hotrod.com/articles/cal-...ck-new-owners/
David Serrano
Old 05-18-2021, 02:16 PM   #16
Ak Sourdough
Ak Sourdough's Avatar
Tanks Inc. also has saddle tanks to fit between the running boards and the frame.
I still have an excellent rememberer, trouble is my forgetter is so much better that it often overrides the rememberer.
Ak Sourdough is offline   Reply With Quote
Old 05-18-2021, 02:45 PM   #17
Randy in ca
Randy in ca's Avatar
Would this conversion be for your sedan? Don't see it on "A" sedans very often and much different than on coupes or roadsters due to the
shorter body subframe and more inner fender exposure. Also it requires a totally different, non stock bumper setup. I may have a picture of a sedan conversion if you're still interested.
Randy in ca is offline   Reply With Quote
Old 05-18-2021, 05:53 PM   #18
Chris Haynes
Gravity. ???
Most likely the same electric fuel pump I am using to feed my Holley/Webber downdraft.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 05-18-2021, 05:54 PM   #19
Chris Haynes
Not all Model A's still use the one bolt updrafts.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 05-18-2021, 06:14 PM   #20
Chris Haynes
https://hosting.photobucket.com/imag...67655037_n.jpg
1921 Runabout
1930 Tudor
Early 1930 AA
