Old 01-24-2021, 11:48 PM   #1
Kevin in NZ
Smile Ford Script Battery
Has anyone managed to fit a modern hi-capacity small 6v battery into the Script battery original case and using the original top covering the conversion so everything looks original. I have heard rumours that it is possible but nothing specific.
Kevin in NZ is offline   Reply With Quote
Old 01-31-2021, 08:26 PM   #2
Rochesterguy
Default Re: Ford Script Battery
It can be done. I have a 33 Victoria with one in it. The top comes off and the modern battery sets down inside. I bought the car with it already installed.
Rochesterguy is offline   Reply With Quote
Old 01-31-2021, 08:53 PM   #3
TerryO
TerryO's Avatar
I have seen an article on how to modify a group 24 battery to hide an AGM battery inside. I can't locate the article now but the battery posts were drilled and tapped to accept a bolt using short cables from the new battery. The old case was drained and the bottom cut out and gutted (safety first). If I can find the article later I will post a link.
TOB
TerryO is offline   Reply With Quote
Old 01-31-2021, 11:16 PM   #4
Kevin in NZ
Thank you for your reply, If you can find it or remember where you read it I would love to find out how to do it.
Old 02-01-2021, 07:25 AM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Why retrofit the Script battery with another battery? Just rebuild your Script battery. If you need a little "inspiration", watch this video linked below and you will understand the basics!
https://www.youtube.com/watch?v=VEvPjOKkPyE
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-01-2021, 09:13 AM   #6
TerryO
TerryO's Avatar
Hey, that looks so simple I think I'll set up a shop like that...
TOB
Old 02-01-2021, 09:40 AM   #7
BRENT in 10-uh-C
TOB
BRENT in 10-uh-C
Old 02-01-2021, 05:18 PM   #8
shew01
shew01's Avatar
Originally Posted by BRENT in 10-uh-C View Post
Wow. Just wow....
Old 02-01-2021, 08:52 PM   #9
TerryO
TerryO's Avatar
I still haven't found the thread with instructions but here are a couple of pictures...
Old 02-05-2021, 08:29 PM   #10
Kevin in NZ
Thank you for that, much appreciated.
Old 02-06-2021, 03:06 PM   #11
Vic in E-TN
Very interesting video posted by Brent Terry about re-manufacturing batteries. This is my experience from the early 60's at National Lead Company in Perth Amboy, New Jersey. I was working in the paint production department. They had a "Battery Breaker" that they activated after dark. It was a 100 ft plus tall escalator that they loaded with batteries a few at a time at the bottom and they dropped off the top. The cases broke open and the acid spilled out on the ground. Ultimately it flowed out to the local water (Kill Van Kull I think) and ultimately into the Hudson River. The rubber and plastic cases were loaded up by bucket equipment and taken to a building where they were smelted and the lead recovered. This was done only at night. The fumes were incredible and mostly the wind blew them over Staten Island. This plant was located next to the Hess Oil Refinery. This was my first experience with industrial pollution at this scale. I did not last long at National Lead. They made "Dutch Boy" Paint which by the way was rated tops by Consumer Reports.
Vic in E-TN is offline   Reply With Quote
Old 02-07-2021, 11:18 AM   #12
Brendan
Brendan's Avatar
TOB
Hell! just do it in your driveway! your neighbors will love you
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 02-07-2021, 11:35 AM   #13
TerryO
TerryO's Avatar
No neighbors...
TOB
Old 02-07-2021, 03:02 PM   #14
Mad Mac
Hey Kevin,
Where do you find good 6-volt Model A batteries in NZ? I can only find deep-cycle batteries (Repco).
Mad Mac is offline   Reply With Quote
