Old 01-24-2021, 06:55 AM   #1
37coop
37coop's Avatar
Default Just won't fire up.
Hi guys....a head scratching problem.
After years of on off restoring my 39 coupe it was on the road last year,it has been out about 4 times and each time it started OK but ran rough.i decided to renew everything that could have effected the problem. New Drake fuel tank and fuel line ,rebuilt later crab distributor, coil and condenser, good pump with an additional electric pump on a switch, new stromberg carb, Cleaned the newish plugs and it wouldn't fire up,I squirted easy start down the carb and it fired up and died when the squirting stopped...I thought it must be the carb so I replaced it with the proven good 94 carb off my 51 truck ( starts first time every time) ,good spark,gas in the bowl and still won't start,not even a cough or splutter when I turn it over..cant think of what else to do, any ideas.?
Thick snow today so will be having a rest from the workshop...thanks, Jim.
37coop is offline   Reply With Quote
Old 01-24-2021, 07:07 AM   #2
ponymare
Default Re: Just won't fire up.
Running rough before could be an over rich carb or weak spark, starting on either but not running could mean low compression, might try pulling the plugs and add a little oil to each cyl, with the plugs out you can check for good fire too.
ponymare is offline   Reply With Quote
Old 01-24-2021, 07:33 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
If you have a glass (or other) fuel bowl on the fuel pump, check the cork gasket. It could be cracked or not tight. Leaking gasket can cause fuel starvation because it will suck air not fuel.
Old 01-24-2021, 08:02 AM   #4
37coop
37coop's Avatar
Thanks for your help,no bowl on the pump and fuel reaching the carb, years ago I did a compression test,the cylinders varied with the lowest being around the 80s and the car fired up ok previously, the fact if fires up immediately with easy start squirted down the carb makes it more puzzling....it does appear to be a fuel problem but a good proven carb and good pump with fuel to the carb.....a puzzle to me.
Old 01-24-2021, 10:12 AM   #5
mfirth
Had a simular problem once, turned out to be bad plug wires. Spark was weak, would not fire gasoline, but would fire on starting fluid. I also have had a bad "new coil" out of the box.
mfirth is offline   Reply With Quote
Old 01-24-2021, 10:48 AM   #6
1931 flamingo
1931 flamingo's Avatar
"Clean" the points?? Pull a plug wire, hold it near away from the plug while someone trys to start the cart, do you have spark??
Paul in CT
Old 01-24-2021, 11:16 AM   #7
TJ
TJ's Avatar
Use a "jumper wire" and bypass the resistor on the firewall.
Old 01-24-2021, 11:31 AM   #8
37coop
37coop's Avatar
Strong spark,I tend to think its fuel delivery ( might be wrong) everything is new except the fuel pump although it appears to squirt ok, I have just orderd a new one even though I have a box of old pumps,
Doing trial by elimination, thanks for your advice
Old 01-24-2021, 01:37 PM   #9
Ken Arms
Ken Arms's Avatar
This is a long shot but my 34 with hydro fuel gauge gave me a problem that tuned out to be embarrassing, the tank was too low on fuel but gauge showed 1/4 tank. Also I got bit by a loose condenser, that little loop that mounts it is a ground and caused intermittent rough running. Ken
Ken Arms is offline   Reply With Quote
Old 01-24-2021, 02:24 PM   #10
petehoovie
petehoovie's Avatar
Make sure the plug wires to distributor caps are installed correctly. - 1 to 1, 2 to 2, 3 to 3 etc....
Old 01-24-2021, 04:16 PM   #11
AnthonyG
AnthonyG's Avatar
If it runs every time w starter fluid u know u got spark & it runs as long as u feed top of carb so it’s gotta b fuel delivery! In ur “renewing all that could b effecting” u mentioned u replaced fuel line & fuel tank. Assuming u thought gas tank & line gunked up? U we’re running it 4 or 5 time but ran rough. Did u run new Carb w old gas tank & line? Did u run pump or elect pump with fuel line into a container before carb to see if u have a good stream of gas? Maybe gunked up fuel pump. If it runs on starter fluid squirted in carb did u try squirting gas into carb after running on starter fluid it should run on gas. Sounds like no fuel getting to /thru carb? Can u see gas coming from Jets with pump running when u actuate accelerator lever? Just writing about what I’d b thinking if me. New fuel pump good thought
Nomad
AnthonyG is offline   Reply With Quote
Old 01-24-2021, 05:24 PM   #12
Als48
Bad or old gas will do that. I have a generator that will not run properly on old gas while the fuel injected Motorhome engine will run on it. Fresh gas and the gen. runs fine. I don't drive the motorhome enough and the fuel goes bad. lts Hard to use 70 gallons of fuel in a vehicle if you fill up but never know when you are going to drive it again. Being 74 yrs old, wife's back surgery, covid restrictions, etc.
Al Hook
Als48 is offline   Reply With Quote
Old 01-24-2021, 06:43 PM   #13
flatjack9
flatjack9's Avatar
I just had a similar problem with my car. Had a hard time starting unless I poured fuel down the carb. Some times it would start just as I was releasing the key. Charged the battery, end of the problem. I've had to start it a number of times to move it around or out of the garage. Guess I just wore the battery down. It's old just like me.
Old 01-24-2021, 08:46 PM   #14
fordyford
fordyford's Avatar
I had a similar problem once. No new parts had been installed (all used parts) and car had been running OK. When I tried to start it several days later the engine would not fire up. I did all of the checks for spark and looked down the carb to see the gas squirt out. Pulled the plugs, tested compression, all was good. Tried starting fluid and it ran for a few seconds. OK the jets must be stopped up. I took the carb top off and found a bowl full of water.
fordyford is offline   Reply With Quote
Old 01-25-2021, 09:03 AM   #15
big job
big job's Avatar
Did you hold throttle wide open and turn engine over with your hand over the carb. you
should get strong vacuum sucking your hand. If not it will never start on its own. Lazy
valves not seating, intake or carb base gaskets ?? try this old trick. take all plugs out,
start with No. 1 turn crank till both valves are down seated looking through the plug
hole with flash light you can see the exhaust valve closed but you can use a straw or
something for the intake to get both valves down. Now stick your shop vac in the plug
hole and listen and feel. the shop vac sound will say a lot as like running wild, there
is a leak, vac bogging down that hole is good and listen to the oil fill pipe for air for
rings. I bet you will find some body leaking. Oh, when and if you get in running, what did
your vacuum gauge say???? probably not much. Bottom line all gas engine need good
carbruater suction to pull fuel through the venturies if not no run .......
big job is offline   Reply With Quote
Old 01-25-2021, 10:38 AM   #16
Ken hash
Ken hash's Avatar
It sounds like you’ve replace everything, and everything is working. I don’t know if you have any vacuum lines running off your intake but if there is a small leak it could prevent your engine from starting. Good luck.
Ken hash is offline   Reply With Quote
Old 01-25-2021, 01:14 PM   #17
big job
big job's Avatar
Yes; I am not word correct; but its like drilling a hole thru ya throat, now you can not breath thru your nose ; is clear as mud, thats the problem.
Old 01-25-2021, 07:39 PM   #18
1941Pony
Vacuum leak? Seems like the engine is not drawing the fuel. Replace intake gasket, carb gasket, check the mating surfaces. One of those smoke machines might find the leak as well.
1941Pony is offline   Reply With Quote
Old 01-25-2021, 08:37 PM   #19
Ron Pilger
Ron Pilger's Avatar
I had a similar issue. After hours of trial and error, I discovered a small air leak at the electric fuel fitting on one of my cars.
Ron Pilger is offline   Reply With Quote
Old 01-25-2021, 09:41 PM   #20
Shu47
Shu47's Avatar
Sounds like a fuel delivery issue to me. You could try attaching a small gravity feed tank directly to the carb and see if that helps.
Shu47 is offline   Reply With Quote
