Old 01-05-2021, 01:51 PM   #1
Mart
Mart's Avatar
Default I'd never have dreamt this would be possible.
I started cleaning the oil pump for the Old 59 Flatty and i couldn't believe what I found.
I would have thought the oil pump would have been the last thing to have rotted out.
Mart.
Old 01-05-2021, 02:02 PM   #2
Zeke3
Zeke3's Avatar
Default Re: I'd never have dreamt this would be possible.
Now that is crusty! Must have been some acidic sludge in the bottom of that engine. How does the oil pan look?
Zeke3 is offline   Reply With Quote
Old 01-05-2021, 02:09 PM   #3
19Fordy
19Fordy's Avatar
Wow! That looks unreal. How can oil do that?
Old 01-05-2021, 02:09 PM   #4
J Franklin
J Franklin's Avatar
All condensation or other water ends up at the lowest level and the oil stays on top of it. Look carefully for cracks.
Old 01-05-2021, 02:12 PM   #5
Aarongriffey
What’s a 59 Flatty?
Aarongriffey is offline   Reply With Quote
Old 01-05-2021, 02:41 PM   #6
Mart
Mart's Avatar
59 series post ww2 flatty. It might be significant that the motor was stored upside down or on it's side. The oil pan is next on the list for a close inspection. There is no sign of similar erosion anywhere else (I hope).
Old 01-05-2021, 02:48 PM   #7
Ronnieroadster
Ronnieroadster's Avatar
Mart just use some JB weld epoxy to cover over those holes it will be good as new.
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 01-05-2021, 02:48 PM   #8
petehoovie
petehoovie's Avatar
Mart,
It seems you have a fetish for "crust"....
Old 01-05-2021, 03:21 PM   #9
Tim Ayers
LOL! Yes, sir.
Old 01-05-2021, 03:29 PM   #10
GB SISSON
GB SISSON's Avatar
Mart, let's face it. The stuff you open up are the ones most people just walk past. And then you go and post a video of it zooming up a hill with a bunch of high dollar(high pound?) cars. Nice oil pump by the way.
Old 01-05-2021, 04:48 PM   #11
Mart
Mart's Avatar
I just went and had an initial scrape about in the bottom of the oil pan. It has some interesting sludgy deposits but luckily and hopefully there doesn't appear to be any corrosion That'll be tomorrow's job, to clean that up. Again, luckily I do have an oil pump I can put in it.
Mart.
Old 01-05-2021, 05:15 PM   #12
cas3
i was once trying to free up a stuck w2 halftrack motor. crowbar on the flywheel, bang! she let loose then felt fine. after tear down i found the oil pump was all that was stuck, and i had sherd off the drive forcing it to turn. oil pan was full of water
Old 01-06-2021, 06:10 PM   #13
corvette8n
corvette8n's Avatar
Hey Mart, how about a video of you brazing up that pump.
