Old 10-10-2016, 10:06 AM   #1
ctinnin
Default Station wagon wood
I used a station wagon in a wedding this weekend. It rained and now the finish is bubbling. Previous owner did wood finish and have no idea what was used. Any suggestions?
ctinnin is offline   Reply With Quote
Old 10-10-2016, 10:16 AM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: Station wagon wood
From what google can share sounds like it got mositure under the protectant or the temp change drew it out of the improperly prepped wood.
http://www.bobvila.com/articles/385-...ting-problems/
Sounds like scrape off and re-finish is in order.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 10-10-2016, 11:19 AM   #3
C26Pinelake
You have a major project ahead of you. Now we know what your winter project will be. Wayne
C26Pinelake is offline   Reply With Quote
Old 10-10-2016, 11:25 AM   #4
Rex_A_Lott
I dont know how to tell you how to figure out what you had, sorry. I think if it was me I would try to talk to somebody with some experience with old wooden boats and try to find a fix or a better solution. Good Luck
Rex_A_Lott is offline   Reply With Quote
Old 10-10-2016, 11:28 AM   #5
ctinnin
Thanks for the info. So far the plan is: let it dry out , take off old finish and use a marine varnish this time.
Old 10-10-2016, 12:14 PM   #6
C26Pinelake
As I said, a winter project! Wayne
Old 10-10-2016, 12:27 PM   #7
Bruce
Bruce's Avatar
Bruce is offline   Reply With Quote
Old 10-10-2016, 12:47 PM   #8
ronn
Bruce has what you want to use. They may have used an interior urethane previously, and therein could be the problem.
Good Luck!
Old 01-14-2021, 03:03 AM   #9
joncrane
Agree Sounds like the station wagon was finished with an interior varnish/poly.
Best Marine varnish I have ever used is Epipanes. Expensive but with many coats it lasts and lasts. Read the instructions, put on 7 to 10 coats. Regular marine varnish is impacted with car wash soaps.
Sitkins varnish is pretty good, but Epipanes is the very best.
Jon
joncrane is offline   Reply With Quote
Old 01-14-2021, 05:57 AM   #10
DBSHELTON
Go to Jamestown Distributors website. I found a lot of info on products there. I am re-finishing parts on my Huckster and am using Total Boat Gleam marine spar varnish. So far so good.
DBSHELTON is offline   Reply With Quote
Old 01-14-2021, 07:26 AM   #11
David R.
Following, eventually building (recreating) a basket case AA huckster. Bright wood looks great but I’m wondering if paint would be more correct and maybe more durable on a huckster?
David R. is offline   Reply With Quote
Old 01-14-2021, 09:11 AM   #12
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Guys, Post #9 that brought up this 5 year old posting is SPAM. This poster (Erik Martin) is not speaking of a Model-A Station Wagon.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-15-2021, 10:19 AM   #13
jb-ob
'ctinin',
Feeling your pain... You might try a plastic credit card to scrape off the blistered varnish. When the card edge becomes dull, cut a fresh edge with a scissor.
If the varnished lifted with water, try soaking an area and repeat scraping. I'd even try blasting it with an air hose to see if the varnish will flake off.
Best.
jb-ob is online now   Reply With Quote
