Old 10-04-2021, 10:26 PM   #1
waynet
Default 6v v 12v Wiring. Is there a load difference?
Folks,
We have taken possession of our recently purchased 1948 M47 Pickup.
The old original wiring is glaring at me and calling fire, fire......
BTW where is the fuse box on these pickups or don't they have one?
Can I replace the old wiring with a new 12v harness and will it handle the 6v amperage? Or should I spend extra coin and convert to a 12v system entirely?
Being a petrol engine we just want safe electrics (nothing fancy).
Much appreciated.
waynet is offline   Reply With Quote
Old 10-05-2021, 12:19 AM   #2
FortyNiner
FortyNiner's Avatar
Default Re: 6v v 12v Wiring. Is there a load difference?
There is not a fuse box in the original configuration. The gauges have simple circuit breaker setups.
The wiring for a 6v system needs to be lower gauge (heavier wire) than a 12v system. Conversion to 12v is often a question of preference and perception of reliability.
Old 10-05-2021, 12:34 AM   #3
ford38v8
ford38v8's Avatar
Waynet, 6 volt harnesses are available from suppliers who serve the hobby. 12 volt can be special ordered, but will not work for 6 volt, as it is smaller gauge wire.
Alan
Old 10-05-2021, 08:26 AM   #4
mercguy
Using this simple equation P=E times I , Power equals voltage times amperage.
It will show you that if you drop the voltage in half, you will double the amperage
through the wire to produce the same amount of power. You will have a tremendous
amount of power lost in the form of hot wires. Starters require a lot of power. Running
a car on 12v using 6v wiring is fine, but not the other way around.
mercguy is offline   Reply With Quote
Old 10-05-2021, 08:59 AM   #5
jayvee34
jayvee34's Avatar
That answers a question that wanted to know for awhile. Thanks. John
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 10-05-2021, 09:55 AM   #6
Crankster
Crankster's Avatar
Is the insulation deteriorated or crumbling? They used (and tried) different materials back then. Pre-war Radios for example used cloth insulation, which has held up really well. Then some manufacturers tried using natural rubber - which has turned to dust and disintegrated. Oops! Just how dangerous is the older 6 volt wiring? It certainly can be, but I'd not necessarily condemn it just on age alone.
Crankster is offline   Reply With Quote
Old 10-05-2021, 12:37 PM   #7
rotorwrench
rotorwrench's Avatar
Where most 6-volt cars will use a 16 AWG wire for a single load circuit, the 12-volt systems only need an 18 AWG wire. You can use 6-volt wiring for 12-volt but you can't use 12-volt wiring for 6-volt. There would be too much resistance for the lower voltage on the smaller gauge wires.
Wiring that caries a higher flow of amperage such as the generator armature wire and the battery buss wire have to be a fair amount larger in wire gauge than just 16 so I would recommend just purchasing a wire harness for the 6-volt systems. If the vehicle is changed currently or at a later date to 12-volt then nothing has to be changed.
Old 10-05-2021, 07:34 PM   #8
waynet
I would describe the insulation being in the early stages of brittle and frayed.
Old 10-05-2021, 07:36 PM   #9
waynet
Thanks for your advice and also others with similar sentiments.
