Old 11-15-2020, 08:26 AM   #1
dono50
dono50's Avatar
Send a message via MSN to dono50
Default Valve lubrication question on 8BA
How does oil get into the valve chamber to lubricate valves and lifters on the 8BA ?
dono50 is offline   Reply With Quote
Old 11-15-2020, 08:38 AM   #2
cadillac512
cadillac512's Avatar
Default Re: Valve lubrication question on 8BA
It's just a combination of oil mist and oil thrown by the rotating crankshaft and rods. Later engines have drilled squirt holes in the rods to supply a bit more to the cam lobes and piston skirts but there's no direct pressure oiling to the tappets or valve chamber.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 11-15-2020, 09:25 AM   #3
dono50
dono50's Avatar
Thanks,Terry
Old 11-16-2020, 11:06 AM   #4
big job
big job's Avatar
Oh, Its not raining but its misty out, so you need ya wipers, and ya face gets wet: So
thats how it works with all makes , valve in block engines for a 100 yrs.
big job is offline   Reply With Quote
Old 11-17-2020, 09:18 AM   #5
mfirth
Yup, and if you want to help those valves add a little M M O....
mfirth is offline   Reply With Quote
Old 11-17-2020, 10:17 AM   #6
GOSFAST
GOSFAST's Avatar
Now's the time to put bronze liners/Stainless valves in and never have a "hung" valve anymore?
You'll need no "additives" either anywhere?
Thanks, Gary in N.Y.
P.S. Bronze-line all 16 guides, install (8) Viton intake stem seals, and "never look back".
File Type: jpg Flathead Bronze Guides-Seals-Valves.JPG (76.0 KB, 36 views)
GOSFAST is offline   Reply With Quote
Old 11-17-2020, 10:37 AM   #7
JSeery
JSeery's Avatar
Is there any advantage to sending you a set of valve guides to modify vs out-right purchase?
Old 11-17-2020, 02:15 PM   #8
GOSFAST
GOSFAST's Avatar
Hi "J", that's what we prefer to do to keep the costs down, use 16 old guides IF you have any?
You can fit 16 used guides in one USPS small flat-rate box, runs about 7.00/8.00
shipped to our P.O. Box.
P.S. It never made sense to me to need to buy 16 new guides and the line them? In the case where there are no old ones available that leaves a limited option. We actually found most used guides are fine for this procedure!
Old 11-17-2020, 03:15 PM   #9
Ronnieroadster
Ronnieroadster's Avatar
To give you an idea of how well the oil splash-mist is in the flathead. For well over 20 years now the roller lifters moving the push rods for the ARDUN rockers in my 59A block have shown no wear at all. That's running the engine around town and thousands of highway miles. Like big job wrote that's how the valve train has worked in engine's for 100 years and counting.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 11-17-2020, 10:30 PM   #10
Ol' Ron
Ol' Ron's Avatar
Another thing you have to realize is the intake valve stem is under Hi Vacuum, but the exhaust is under pressure, and need kubrication or they seze.
