Old 11-06-2020, 09:33 AM   #1
big job
big job's Avatar
Default Dip stick ?
All my yrs I should know this, but I got cobweb brain damage. Ok new engine
a 59AB with now 3500 miles. Since day one 5qts says full on the stick. Last
week oil change now 4 quarts says full. I just now, think the dipstick washer
slid up, which will sink the stick lower. So before I start pulling dipsticks from
engines in stock ranging from 1934 to 1953, is there a dip stick chart? Like
I said I should know this, but I rebuild engines not dipsticks. so I'm embarrassed. sam
big job is offline   Reply With Quote
Old 11-07-2020, 03:41 PM   #2
Ken Arms
Ken Arms's Avatar
Default Re: Dip stick ?
Hey Sam, I changed the pan on my 59ab since it had a modified (baffles) 34 pan on it and I was getting blow by pressure leaks, I put a used pan on that has the vent made for 59 engine. The pan had no dip stick or tube, I ordered one from China that said fits 59ab but it shows over full with 5qrts. I made a new mark on dipstick (washer up all the way) good to go and no more leaks. Ken
Ken Arms is offline   Reply With Quote
Old 11-08-2020, 06:00 AM   #3
big job
big job's Avatar
interesting Ken, I did check the 'stick' washer and it did not slip. Only way to solve
this puzzle is the next oil change maybe I got a phone call and my brain lost count LOL
Old 11-08-2020, 06:17 AM   #4
Terry,OH
Terry,OH's Avatar
There is a dip stick chart in one of the Chassis Parts Manuals. I do not have it.
Old 11-08-2020, 07:33 AM   #5
glennpm
glennpm's Avatar
Here is the length chart from the Green Book. On the previous page there's a length for the 4 cylinders at 9-1/8" long.
Glenn
Old 11-08-2020, 08:07 AM   #6
glennpm
glennpm's Avatar
The chart above lists the length from tip to extreme of handle and not the length from the top of the tube to the tip in the oil. I have a 59A and these are the measurements:
Overall length = 16-3/4" (Green Book lists 16-5/8")
Length form tip to felt washer = 13-3/4"
Tip to full mark = 2-1/8"
Tip to top of danger mark = 3/4"
Old 11-08-2020, 08:11 AM   #7
glennpm
glennpm's Avatar
Oh and I put in 4qts - 18oz to get to the full mark. I have an external filter.
Glenn
Old 11-08-2020, 09:28 AM   #8
big job
big job's Avatar
Thanks a lot Glenn for your post. But then again same original stick same
engine all previous oil changes = 5 qts full this time 4qts full ?? I use 20-50
racing oil its got zinc from Napa maybe I got litres in stead of quarts? LOL
sam
Old 11-09-2020, 07:56 AM   #9
glennpm
glennpm's Avatar
You're welcome! Can't figure why you would get a quart difference unless the dipstick was being pushed out of line due to the pan oil baffle.
Glenn
Old 11-09-2020, 08:18 AM   #10
JSeery
JSeery's Avatar
sam
Can you secure the disk on the dipstick where you want it, then fill the block with five qts and remark the full line?
Old 11-09-2020, 09:23 AM   #11
big job
big job's Avatar
but the disk is swaged right where it belongs plus I painted the 'loop' yellow so
I can see the thing. There is some thing stupid going on here, again last 5 oil
changes = 5 qts full mark this time 4 qts full mark. Is a litre more than a US
quart thats all I can think of, we did not have that litre stuff in high school.
Old 11-09-2020, 09:29 AM   #12
big job
big job's Avatar
Glenn
Ah there is no baffle in this pan its a 59AB 1946
Old 11-09-2020, 09:36 AM   #13
JSeery
JSeery's Avatar
Ok, not trying to be a wise-guy here, but is there any chance you lost track of the number of quarts added?? Being off exactly 1 qt seems like a hint. Sure wouldn't be the first time I convinced myself I had done something correctly to later find out I didn't!!!
Old 11-09-2020, 09:46 AM   #14
Zeke3
Zeke3's Avatar
The large containers of oil, Castrol and Valvoline, that I have purchased lately for Wallyworld are 5 qts instead of 1 gallon.
Zeke3 is offline   Reply With Quote
Old 11-09-2020, 10:27 AM   #15
Jacques1960
Jacques1960's Avatar
As an aside, I purchased a dip stick (Chinesium of course) for a ‘47 Willys - it was beautifully made, correctly marked and....painted
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 11-09-2020, 10:28 AM   #16
big job
big job's Avatar
No way you are a wise guy. gettin so If I forget to write a note for a note
then all is for not. so your right I probably put 5 in there in the first place.
So I'm bad, wanna see notes she wrights thanks sam
Is our build clean?
