Old 03-09-2021, 07:54 AM   #1
Desoto291Hemi
Default Flathead radiator with straight water
I know I am not that bright .
I read a lot of posts here where you should put straight water in the radiator with no antifreeze during a test .
Why ?
I have seen several pics here where the Block had a chunk the size of your fist pushed out ,,or a crack running the length of the pan rail or some other disastrous outcome from freezing .
I can understand doing for a short test,,,,,,but looks like too many are forgetting and leaving the water in without mixing in antifreeze .
What is wrong with putting some antifreeze in while doing a test .
If it is cracked already,,,,,the antifreeze won’t hurt any thing more than is already hurt ?
Just curious !
Tommy
Desoto291Hemi is offline   Reply With Quote
