Old 09-06-2020, 09:37 AM   #1
lrjones
Default Brake Cross Shaft Diameter
I'm going to replace the service brake cross shaft bushings on my '31. I was wondering what the diameter of the shaft, where the bushing go, should be to safely use the standard 2 piece bronze bushing. I would want to order a repair kit the same time that I order the bushings if needed. Thank you
lrjones is offline   Reply With Quote
