Old 06-26-2016, 08:31 PM   #1
John Schlegel
Default Leg room
How can I get more leg room in front seat 1929 fordor.
Gear shift gets in the way so I can,t apply brakes when in first gear.
Stock seat is all the way back
John Schlegel is offline   Reply With Quote
Old 06-26-2016, 11:12 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Leg room
Hi John, I had the similar problem in my '30 Town Sedan. At a stop light with my foot on the brake and shifter in first, I had a hard time getting my foot off the brake pedal and on to the gas peddle. This after moving the front seat 3" back.
I ended up bending the shifter towards the passenger side ~1-2".
There was a thread on this a little while back but I can't seem to find it now. Perhaps someone else can help...
I made this simple tool out of items I had on hand to bend my shifter. You put the shifter thru the eye bolts and tighten the Big Blue Nut.
Old 06-27-2016, 05:00 AM   #3
Mitch//pa
Move the seat back, make or buy a 6" adjuster. Snyders has them but pricey...
Here are the snyders adjusters,, I believe they are the only ones supplying these. I have them in both my cars, they do look decent installed
Old 06-27-2016, 06:22 AM   #4
john in illinois
john in illinois's Avatar
I have made several of these for myself and club members. Uses holes from original seat bracket.
John
john in illinois is offline   Reply With Quote
Old 06-27-2016, 06:36 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
John
The Fordor won't be as easy as the Tudor to move the seat back.
Old 06-27-2016, 09:15 AM   #6
john in illinois
You are right Tom, I have only made tghem for Tudors.
John
Old 06-27-2016, 10:07 AM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
John S,
I heated Minervas' shifter at the fat end, with a propane torch, took me 3 tries to get it RIGHT!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-27-2016, 11:20 AM   #8
pgerhardt
pgerhardt's Avatar
Moving the seat back will NOT correct the problem of your leg being trapped under the steering wheel when in first gear. The distance between your knee and the steering wheel will stay about the same. The problem is that the shift lever is leaning a little toward the drivers side, so when in first it traps your leg under the steering wheel. The solution is to bend the shift lever so it leans a little toward the passenger side. This will leave a little space for your knee to come up past the right side of the steering wheel. On mine I just grabbed the lever and pulled a little. It bent easily. A ten second fix!
pgerhardt is offline   Reply With Quote
Old 06-27-2016, 11:33 AM   #9
Y-Blockhead
Haha. You're braver then me. I was afraid to "hurt" something internally, hence the tool I made (post #2).
But either way I agree. Moving the seat back 3" in my Town Sedan was NOT easy and the results were not what I had hoped for. Bending the shifter will alleviate your problem.
Last edited by Y-Blockhead; 06-27-2016 at 11:35 AM. Reason: I hate auto-spell correction...
Old 06-27-2016, 01:07 PM   #10
Mitch//pa
Most home made adjusters DO NOT tilt in the front.. These adjusters from snyders DO which gives clearance under the steering wheel as well as moving the set back 6"...it works I have these in both my Tudors, the extra leg room and clearance is valuable for my comfort.. Never had a need to bend the shifter with these installed. Even just bending the shifter out of the way I would've needed these anyways for overall comfort so this killed two birds with one stone
Old 06-27-2016, 01:30 PM   #11
Tom Wesenberg
I plan to move my 29 Tudor seats back a couple inches, and I wouldn't bend my shift lever. I'm actually OK with the seats as is, but a couple inches back would be more comfortable and make getting in easier.
I would never just push the shift lever to the side to bend it, but would make a tool like Y-Blockhead shows to bend the lever.
Old 06-27-2016, 01:32 PM   #12
Mitch//pa
Times 2
Old 06-27-2016, 01:52 PM   #13
Y-Blockhead
But you guys are talking Tudors. The OP has a Fordor (As do I). The Snyder's Seat Mover Backer is for the Tudor. http://www.snydersantiqueauto.com/seat-adjuster-kit Won't work on a Fordor.
Old 06-27-2016, 01:56 PM   #14
Mitch//pa
OH your right... I'm a Blockhead u can relate to that. At Least I brought Tom on the ride with me......
Old 06-27-2016, 02:57 PM   #15
1931 flamingo
1931 flamingo's Avatar
Mine's a udor also and have similar to post #4Plus I raised the seat a couple of inches.
"Form" the shifter to the right AND move the seat back 3". There should still be plenty of room for back seat passengers, if you ever have any. FWIW
Paul in CT
Old 06-27-2016, 03:04 PM   #16
ODFever
ODFever's Avatar
I'm 6'2" and 220 lbs. I found a couple of ways to increase legroom without major modifications. I removed the rubber pedal pads. I bought a pair of PF Flyers (similar to Converse Chuck Taylor's). The thin sole gives me the extra legroom to get my size 15 wide feet on the pedals.
ODFever
1930 Ford Model A Town Sedan "Alyssa"
ODFever is offline   Reply With Quote
Old 06-27-2016, 03:14 PM   #17
Will N
Will N's Avatar
When you eventually go to have your knees replaced, ask the surgeon to take an inch or two out of your leg. That ought to fix the problem ;-)
Will N is offline   Reply With Quote
Old 06-27-2016, 03:21 PM   #18
Y-Blockhead
Hey, hey! I resemble that remark...
Old 06-27-2016, 05:17 PM   #19
garyjohn
Smile Re: Leg room
You should have made the remark about having the surgeon shorted my leg a couple of months ago and I could have had him do it then. too late now
garyjohn is offline   Reply With Quote
Old 06-27-2016, 08:37 PM   #20
BILL WILLIAMSON
I can give a THUMBS UP to that!---Can you?
SA Dad
