Old 07-20-2020, 04:18 PM   #1
bo8109b
bo8109b's Avatar
Default '40 Radio Problem
'40 Philco plays weak on only one station. Discovered that momentarily touching antenna to ground with a 1.5 test light produces full volume on 6 stations for 8 minutes, then dies back.Same way in the car or on the bench. Know nothing about electronics. Can anybody help with this? Carl
bo8109b is offline   Reply With Quote
Old 07-20-2020, 05:08 PM   #2
corvette8n
corvette8n's Avatar
Default Re: '40 Radio Problem
Guessing a capacitor problem, if your adventurous you could unsolder and replace the capacitors one at a time. Probably best to send it out for repairs.
Old 07-20-2020, 05:14 PM   #3
Pete
That is a problem a repair shop that is familiar with old tube type radios needs to fix.
If you should open up the box be aware that there is a high enough voltage inside, when the radio is on, that will light up your ears if you contact it.
Old 07-20-2020, 08:58 PM   #4
FortyNiner
FortyNiner's Avatar
Take a look at this fellow in northern Illinois. https://www.car-radio-conversions.com/
Old 07-21-2020, 09:35 AM   #5
Kens 36
Kens 36's Avatar
Ralph has done two radios for me - highly recommended. He can repair an original radio to operate like new, or he can replace internals with modern circuit boards for AM/FM, iPod/MP3 jack, even Bluetooth.
Ken
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 08-08-2020, 03:39 PM   #6
bo8109b
bo8109b's Avatar
As Forty Niner & Kens36 reference to "Ralph the Radio Guy", This guy repaired my radio and several other things all at reasonable cost. I too highly recomend him. Located in Bartlett, Ill. 1-773-814-5094
Old 08-16-2020, 09:23 AM   #7
philipswanson
Get it converted to modern electronics. Mine even works on a thumb drive with pre recorded music. Also no static.
philipswanson is offline   Reply With Quote
