Hello, I have a 29 Model AA and recently had to replace the lower plate due to a bad wire, anyway had to redo the timing. I started with spark advance all the way up, found TDC on timing gear, used Nu-Rex wrench adjust and now truck only starts with spark advance lever all the way down. Do I start over? Perhaps I was not top dead center when i started? Im Assuming it’s way too advanced, sounds good when running with lever all the way down but I know that’s not right and looking for a little guidance.
Thanks |
most likely you were in error as to TDC. Did you double check that?
Jay did you have the body of the distributor on and turn the pointer on the wrench to the #4 post on it or did you by chance not have the body on the distributor and instead put the pointer at the #4 spark plug?
If you had it at top dead center, advance lever all the way up and the spark control arm touching the passenger side of the distributor body and the nurex touching the #4 contact on the body it should be pretty darn close to spot on. Another possibility is you may not have had the screw turned tight enough and the rotor moved.
Dave / Lincoln Nebraska |
#4 | |
![]() Quote:
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 06-24-2020 at 12:55 PM. |
Picture shows where rotor is point correctly to spark plug oone when at TDC - check and see if your is correct. Lookikn from passanger side of the motor.
Other picture shows were wrench should be when timed - wrench pointing towards firewall |
Pictures.
One of the rotor when it is at TDC cylinder 1 - check to see if you get the with the timing pin located properly . Other picture is the wrench is set properly timed - wrench handle toward fire wall. (spark lever at full retard/up). |
left lever up
points set to .020" TDC found with timing pin distributor cam notch toward #1 pin in cap [ pointing toward right fender] distributor spins CCW set cam so ramp just contacts points block with backlash removed. tighten cam screw, recheck as cam can move. any more turn of cam CCW or pulling the lever down a click or two will open points. [ a continuity meter works well ] timing is now set correctly Last edited by Patrick L.; 06-24-2020 at 05:20 PM. |
Yes I thought about this also, I did bend it but maybe not enough, was going to recheck it
#10 | |
![]() Quote:
Hey thanks all for the suggestions it was the lower plate wire where it connects to the upper plate was not bent in enough could see where it was making contact, all is well now and drove bing around, thanks again
#13 |
Thanks for the feedback. It may help others.
Paul in CT |
