Old 06-13-2020, 11:03 AM   #1
guy1unico
Default Squeaky 40 juice brakes - practically new
These front 40 brakes are squeaky and practically new. Is there a trick I don't know about to eliminate the dang squeak?
Thank you,
Guy
guy1unico is offline   Reply With Quote
Old 06-13-2020, 11:07 AM   #2
philipswanson
Default Re: Squeaky 40 juice brakes - practically new
I would switch to Bendix brakes up front. MUCH better.
philipswanson is offline   Reply With Quote
Old 06-13-2020, 11:29 AM   #3
19Fordy
19Fordy's Avatar
If they squeak when you apply the brakes, your brake shoes may be glazed smooth.
Remove the drums and sand each shoe surface with 60 grit sandpaper to make them rough. Wear a mask and don't air bow the dust away.
Also use sand paper to rough up the inside dia. of the contact surface of each drum.
Then go for a ride.
OEM shoes were made of softer material and were riveted on.
Bonded shoes use harder materials.
Old 06-13-2020, 12:25 PM   #4
Kube
Kube's Avatar
Thank you,
Guy
Much of this depends on the quality of the shoes and proper contact to the drums.
Did you arc the shoes to fit the TURNED drums?
If you simply replaced the shoes and put the used drums back on, you are likely going to live with the squeak...
Old 06-13-2020, 01:10 PM   #5
guy1unico
Thank you, good advice I'll go work on them.
Old 06-13-2020, 01:29 PM   #6
Lawson Cox
Lawson Cox's Avatar
Thank you,
Guy
Grease them. LOL (No !! Don't do that. Just pullin' your leg. )
