Old 05-25-2020, 09:44 AM   #1
DBSHELTON
Default Distributor Shaft Sleeve
I need to re-install the Shaft Sleeves on a couple of Distributors I took apart and rebuilt. Would it be OK if I used 1/8" dia Roll Pins instead of 1/8" solid pins?
DBSHELTON is offline   Reply With Quote
Old 05-25-2020, 09:51 AM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Distributor Shaft Sleeve
Yes it is fine as long as it is thr right length and holds it tight.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 05-25-2020, 09:56 AM   #3
dbaldwi3
dbaldwi3's Avatar
Agreed
dbaldwi3 is offline   Reply With Quote
Old 05-25-2020, 10:49 AM   #4
ryanheacox
ryanheacox's Avatar
Sounds good to me. I believe the new sleeves you would get from the vendors come with a roll pin instead of solid as well.
Old 05-25-2020, 12:26 PM   #5
DBSHELTON
I just put 2 together and everything is tight. Used the same roll pins as small block and big block Fords use.
