Is foaming coolant (about 50/50 anti-freeze/distilled water) an indication of a blown head gasket?
Typically. It could also be a crack in the head or block where combustion gasses are entering the coolant.
I had foaming after 10 miles at 50 MPH. Looked like whipped cream. Made me sick. No overheating indicated. Had cheap antifreeze, tap water, and off brand stop leak. Drained it all put in 50/50 Prestone, distilled water. No problem since. I suspect it was a mixture of what I put in the radiator that just got whipped into a foam, went all over the windshield and hood. Stopped and put 1/2 gallon of water in and continued 35 mile trip. No problem since.
Just my personal experience. Hope you discover something as simple. |
Foaming is an indication that the water pump is mixing air into the coolant. This may be the result of:
>Coolant type or additive; >Restriction in the coolant inlet route to the pump. In many cases a thermostat in the coolant outlet hose to the radiator solves the problem. Another cure is run a stock radiator cap instead of a flip-top cap.
Bob Bidonde |
Yep. The air getting whipped into the system is likely combustion gas leaking past the head gasket. Any idea which head gasket your engine has on it?
#7 | |
![]() Quote:
Stopping the water pump from turning reduces the chance of what Bob pointed out... air leaking in as the source of the foaming.
What you should see is nice big bubbles coming to the surface, especially when you speed up the engine a bit and create more pressure leaking thru the defective gasket surface. |
Thanks to all. I'm pretty sure it's a blown head gasket or crack in the block or head. I'll try a couple of these tests and see what happens.
A leak down test will tell you everything you need to know.
A lot of good suggestions. The first thing I would do before tearing it all apart is re-torque the head. It may prevent a lot of heartburn. Then proceed from there. Good luck.
The Master Cylinder Enjoying life at the beach in SoCal... |
An alternate test for exhaust gas in the coolant - Block Test Kit, tests the air in the upper radiator tank for exhaust gas. Can easily do yourself, or check around at radiator shop or your local independent shops. Usually cheaper on amazon.
https://www.napaonline.com/en/p/BK_7001006 |
#13 | |
![]() Quote:
That's the kit I have. Here is what a slight leak looks like, a bad leak should turn the fluid yellow. |
