Old 04-24-2020, 11:06 AM   #1
Seattledavid
Default Model A engine pans
Does anyone have a photo of what the pans look like installed?? I can’t figure out how they go in. I think the side with the tabs goes to the oil pan side. One of the pans has a U shaped cutout which side does that go on. Is it the steering wheel side? Does the larger end of the pan go towards the back of the car and do the pans go in either the curve up or the curve down? Thanks for any info.
Dave
Seattledavid is offline   Reply With Quote
Old 04-24-2020, 11:13 AM   #2
Ruth
Default Re: Model A engine pans
Dave, the u shaped cutout is for the exhaust pipe. the side with three holes bolts to the frame. The two tabs go to the oil pan. Uses two of the oil pan bolts to attach. Curved down, larger end to rear.
In the picture below, left side passenger side of car, right side drivers side. (assuming you have a right hand drive car.
Ruth
Old 04-24-2020, 11:15 AM   #3
rocket1
according to Les Andrews book two dust pan tabs are under two of the oil pan bolts and the other side is fastened to the frame with 3 1/4-28x1/2 hex head bolts,curviture would face down and u shaped hole would wind up under carb.sorry no pic.
rocket1 is offline   Reply With Quote
Old 04-24-2020, 11:41 AM   #4
Ruth
Forgot to mention, I tapped the 6 holes in the frame rails for 5/16"-18 bolts for easier install from underneath.
Ruth
Old 04-24-2020, 11:50 AM   #5
Seattledavid
Thanks so much for the input. I understand now.
Dave
Old 04-24-2020, 02:23 PM   #6
Bruce of MN
Bruce of MN's Avatar
For some reason, I didn’t take care of it 10 years ago when I had the motor out, but this time, I had to relieve the pan flange at the oil pump bulge and a couple other spots, too.
Old 04-24-2020, 02:29 PM   #7
Tom Endy
Tom Endy's Avatar
The tabs that bolt to the engine pan will want to break off due to vibration and flexing. When they do, they will let out a howl during de-acceleration. Best to make up some support brackets when installing.
Tom Endy
Old 04-24-2020, 02:50 PM   #8
Davew
Davew's Avatar
Tom, what would the support brackets look like? Would they go over the existing tab?
Davew is offline   Reply With Quote
Old 04-24-2020, 03:54 PM   #9
alexiskai
alexiskai's Avatar
Here's an earlier thread with some additional solutions for the flex problem:
https://www.fordbarn.com/forum/showthread.php?t=45594
Old 04-24-2020, 06:07 PM   #10
shew01
shew01's Avatar
I don’t know if this helps much, but here are some pictures of mine.
Old 04-24-2020, 06:08 PM   #11
shew01
shew01's Avatar
Yes, I know I have a radiator leak. ;-) My replacement radiator arrived a few weeks ago, but I haven’t had a chance to swap it out yet.
Old 04-24-2020, 06:09 PM   #12
shew01
shew01's Avatar
Large ends go toward the rear of the car.
Old 05-08-2020, 12:10 PM   #13
sam heller
The flat ends go at the front of engine Curved ones go toward rear. This is the way they were on my 1931 4 door sedan.
Any place to get a set?
Sam Heller
sam heller is offline   Reply With Quote
Old 05-08-2020, 12:43 PM   #14
daren007
They are only going to in one way.
daren007 is offline   Reply With Quote
Old 05-08-2020, 09:26 PM   #15
al's28/33
al's28/33's Avatar
Shew01 … I would get rid of that paper air filter on your carb, swap it out for the steel screening type. Eliminate the fire hazard.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
