Old 04-20-2020, 12:19 PM   #1
jg61hawk
Default Bendix Spring Snapped...Normal?
So the attached photo is my Bendix Spring. I ordered a new USA made set up from Synder's. Any thoughts? I think it backfired on starting, would that crack it, or just wear and old age?
jg61hawk is offline   Reply With Quote
Old 04-20-2020, 12:44 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Bendix Spring Snapped...Normal?
I know that the bolts do break! Hard to say Old age? How old is it?
www.whidbeymodelaclub.com
Old 04-20-2020, 01:34 PM   #3
Herb Concord Ca
Springs do break also.
Herb Concord Ca is offline   Reply With Quote
Old 04-20-2020, 02:22 PM   #4
jg61hawk
It's probably 20 years of service. I have another question, if the bolt goes through the shaft why have key? Seems the bolt would hold everything where it belongs without the key. Just curious. I took it apart (my first one) a few hours so maybe I'm forgetting what I saw. Thanks.
Old 04-20-2020, 02:34 PM   #5
chrs1961815
chrs1961815's Avatar
Think of how many times you have started the car in twenty years. I think you got your service out of it.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 04-20-2020, 02:36 PM   #6
Floats
Floats's Avatar
Hawk,
I have fitted 12 batteries in my 28 Pickup as well as in my 29 Chevy. The extra oomph causes the starter to kick in with a hell of a jolt. In the past five years or so, I have had a few broken springs on the Chevy and the Model A. I have also had one where the bolts securing the spring, have come loose. I now fit them with locktite and make double sure that the lockplates are secure.
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
Old 04-20-2020, 03:06 PM   #7
daveymc29
daveymc29's Avatar
12 batteries. No wonder some springs broke. I have broken them with one 6V battery.
daveymc29 is offline   Reply With Quote
Old 04-21-2020, 06:19 AM   #8
Floats
Floats's Avatar
You are correct Davey,
6 Volt batteries are very hard to come by in Africa.
Cheers
Regards
Chris
Cape Town
Old 04-21-2020, 09:34 AM   #9
1931 flamingo
1931 flamingo's Avatar
When putting the new spring on make sure you use the special washers under the bolts.
Paul in CT
Old 04-21-2020, 11:15 AM   #10
katy
katy's Avatar
That's the first one I've seen/heard of where the bolt goes right through the shaft.
Old 04-21-2020, 12:25 PM   #11
Redbird
Redbird's Avatar
Mine broke from back firing soon after I got the car. Learning curve of starting a Model A. For sure get the new washers with the bend over tab!!!!
Redbird is offline   Reply With Quote
Old 04-21-2020, 12:42 PM   #12
Tom Endy
Tom Endy's Avatar
My suggestion is to install the modern Bendix that most suppliers offer. Especially if you are operating a 6-volt starter on 12-volts.
Tom Endy
Old 04-21-2020, 01:07 PM   #13
Ruth
Tom Endy
Ditto. I converted my 6v stater to 12v and it still hits hard. Go with the modern Bendix. I have never had a problem.
Ruth
Old 04-21-2020, 01:23 PM   #14
McMimmcs
McMimmcs's Avatar
Broken bendix spring with a 12 volt battery can be expected. No surprise at all.
Old 04-21-2020, 11:45 PM   #15
norcalal
I am surprised no one mentioned retarding the spark before hitting the starter. Does this imply that 12 volts make the engine kicking back a thing of the past. And only with 6 volts? I h ave done that!
norcalal is offline   Reply With Quote
Old 04-22-2020, 12:12 AM   #16
Bill G
Bill G's Avatar
6 or 12 volts... No difference on spark advance. Always retard on start-up.
Old 04-22-2020, 10:58 AM   #17
Purdy Swoft
Purdy Swoft's Avatar
Besides breaking The Bendix spring , failure to retard the spark when cranking can bend the armature shaft .
Old 04-22-2020, 11:12 AM   #18
redmodelt
redmodelt's Avatar
Re the bolt going thru the shaft out the other side, farmer fix for stripped threads or missing key? Don't know/think you if could even use a modern bendix on that shaft. ?
Not a recommendation just posting to show it mounted.
https://www.macsautoparts.com/ford_m...E&gclsrc=aw.ds
Old 04-22-2020, 10:42 PM   #19
redmodelt
redmodelt's Avatar
The the retaining bolt and washer are installed the spring is left a some movement. The bolt is turned tight then back off to the first flat before the tab is bent up. In this case that bolt that goes all the way thru may have been way to tight. At this point I think that you would need a replacement armature as the hole is now over sized. Is the key in place?
Old 04-24-2020, 09:50 AM   #20
jg61hawk
REDMODELT: Please see my new thread...Help Weird Starter Drive and Shaft.......I think I got a problem... Do the shafts have a hole in them? See my other post...please.
