Hi Everyone,
I am brand new to the form so please forgive me if I do anything wrong! ![]() My grandpa owns a 1930 Model A roadster that both he and I enjoy working on and driving! When he restored the car in the early 60's, he upgraded it to hydraulic brakes, however, recently the brakes have become pretty poor and we were just wondering if anyone had converted their Model A to Lincoln style Bendix brakes with the MT Car Products kit? ( either just the front or all four) Thanks, Colin |
Bendix brakes will definitely work better than the Ford fixed anchor hydraulic brakes.
Several members of our local club have replaced the Ford 39-48 brakes with the Lincolns on the front only and they are very satisfied. Converting to hydraulic using 39-48 Ford brakes is not much better than good working original Model A mechanical brakes. The reason a lot of people converted to hydraulic in the "Old Days" was that most people had worn out mechanical brakes and they would not put in the work to fix them correctly. My opinion, Chris W. . |
It might be interesting to explore what is wrong with your existing brakes and what it would cost to fix them. When you get the complete cost of the Lincoln brakes you will have a number to compare. The Lincoln brakes are definitely an improvement but I can never say I have been unhappy with the '39-''48 brakes. I always thought they were a major improvement over the stock mechanical brakes, my opinion (sure to start a discussion).
You should put your general location in your profile, you can never tell how or when it will pay off. So to get started, what are your existing brakes and what is wrong with them? Pictures are good. Charlie Stephens Last edited by Charlie Stephens; 04-26-2020 at 09:40 PM. |
I am curious about this as well because my current 1940 Ford front brakes have leaky and pitted brake cylinders and the cost of replacement Lockheed wheel cylinders is significant compared to the cost of the new MT backing plates complete with Bendix wheel cylinders that are actually designed for the 28-'36 spindles. The 1939-41 Ford backing plates require use of a spacer ring and modification of the mounting holes, which has always seemed slightly marginal to me.
Interesting! Thanks for the info. We are probably going to do the front brakes only to keep the cost down, so it's good to hear some positive reviews!
As for the problems with our current brakes, they are 1947 Ford brakes and the drums have been overcut, we don't think the linings are making good contact, and you can't lock them at all. ( Yes we have tried adjusting them) I think they are just worn out, and we just think we should upgrade from a safety standpoint. If anyone else has experience with the MT Car Products Bendix Brakes kit, we would love to hear about it! Thanks, Colin |
Paul in CT |
#7 | |
![]() Quote:
Charlie Stephens |
I would return to the original brakes .
Agree with Purdy.. Recently bought a Victoria that had so many HD brake problems we went back to mechanicals. They work great. Problem solved
I noticed the harder I work the luckier I get! |
1931 flamingo - I asked my grandpa(I personally don't know a lot about this area, but am learning!) about why he didn't want to just get new drums and he said that drum replacement requires that the original hub(the one that holds the bearings) to be pressed into the new drum. He said that this is a special shop procedure and that he likes the better design of the Bendix Brakes more than the original.
Charlie Stephens- I didn't personally do any measurements, but I will ask my grandpa if he did recently. We are both located in Huntington Long Island(I will have to complete my profile evidently) I don't think we put new shoes in it recently, but I will check. Purdy Swoft/MAG- I think my grandpa is pretty set on upgrading to the Bendix brakes, he thinks they are a much better design and had good results with them on his second hot rod he built back in the 50's. I have no doubt that a good set of original brakes would be decent, but I don't think he would go for that. I will ask though! Thanks, Colin |
I have run '39 style brakes for some 60 years, and find them a big improvement over stock brakes. Several years ago I put Lincoln brakes on the front axle of my wide-bed, found very little, if any, improvement over the '39 Ford brakes. Lincoln, and the M/T brakes are the same diameter and width as 39-48 Ford brakes, the advantage is the servo action of Bendix brakes, theoretically less pedal pressure is required, but I see very little difference. I use, and recommend, silicone brake fluid (DOT 5). It rejects water, other fluids attract water which results in rusted and frozen cylinders. All the hydraulic's should easily lock up the wheels, Colin583 must have additional problems. Stock brakes MAY BE okay at slower speeds, IF adjusted properly adjusted, not so good at highway speeds and long down-hills.
There's a large Model A Club on Long Island, they must know of a place that can install the studs and turn the drums. A lot cheaper and then adj the brakes. I have good brakes on my 40, everything original. FWIW
Paul in CT |
#13 |
Unless there has been further work done the Lincoln brakes also require a special shop procedure to replace the drums. Of course if you buy everything new you won't have the problem.
Charlie Stephens |
