Old 04-13-2020, 06:07 PM   #1
Art Newland
Art Newland's Avatar
Default Holley 94 auestion
While trying to get two usable carburetors together, I ran across this one that has a different fuel line fitting. Is this something that came stock or maybe it was used to repair the fuel inlet threads?
"whatever works!"
Art Newland is offline   Reply With Quote
Old 04-13-2020, 06:28 PM   #2
Art Newland
Default Re: Holley 94 auestion
another pic
"whatever works!"
Old 04-13-2020, 10:18 PM   #3
ford38v8
ford38v8's Avatar
Yes, that’s a repair. More than one way to skin a cat, repair fittings have been around since back in the day, yours looks to be a modern version.
Alan
Old 04-13-2020, 10:27 PM   #4
Art Newland
Any idea where I could get another?
"whatever works!"
Old 04-14-2020, 08:27 AM   #5
jimvette59
jimvette59's Avatar
It's a heli coil repair thread size 7/8 x 20 TPI. Look it up on Google.
jimvette59 is offline   Reply With Quote
Old 04-14-2020, 09:58 AM   #6
Art Newland
Thanks!
"whatever works!"
Old 04-14-2020, 10:34 AM   #7
Russ/40
Russ/40's Avatar
I thought helicoils were stainless. That looks to be a brass insert of some kind. Keensert?
Old 04-14-2020, 10:46 AM   #8
flatrod
flatrod's Avatar
The threads in a 94 bowl should be 1/2 x 20. That does look like a insert to me not a helicoil. I think either will work as long as its installed square, it has to seal with the gasket.
flatrod is offline   Reply With Quote
Old 04-14-2020, 10:55 AM   #9
Mart
Mart's Avatar
You'd probably be able to find an unmodified carb top easier, Art. Unless the repair is truly a commonly found and well known device.
Old 04-14-2020, 11:02 AM   #10
tubman
tubman's Avatar
I would think a common Helicoil would have a tendency to leak in that application. I would prefer to use some kind of insert.
Old 04-14-2020, 11:28 AM   #11
Art Newland
You're probably right Mart, my bench already looks like a Holley 94 graveyard. I do have another coming in the mail that looks to have good threads. This seems to be such a common problem you'd think someone would make a repair kit. I'm a repairman at heart, I want to fix it!
"whatever works!"
Old 04-14-2020, 03:29 PM   #12
scicala
scicala's Avatar
How could it possibly be a 7/8 x 20 thread ? The boss on the carb isn't even that big.
Sal
scicala is offline   Reply With Quote
Old 04-14-2020, 03:54 PM   #13
L-head
The brass part that is marked ".098" looks to me like the fuel inlet/seat of off a Stromberg 97? I don't think it's a 94 Holley part.
L-head is offline   Reply With Quote
Old 04-14-2020, 09:13 PM   #14
Art Newland
Default Re: Holley 94 question
Looks like you are correct, there is a Stromberg fuel inlet that is .098 orifice.
"whatever works!"
Old 04-15-2020, 10:16 AM   #15
Art Newland
I think this is the thread insert;
https://www.stromberg-bulletin.com/s...et-thread-fix/
"whatever works!"
Old 04-15-2020, 12:16 PM   #16
Mart
Mart's Avatar
Not sure what Clive is saying by never seeing a 1/2" thread. They're all 1/2" by design.
I wonder if the fix was to take them to 9/16"
I've never had a stromberg, can I assume the thread is the same as a 94? 1/2"-20?
I'm just going by my 94 experience.
Mart.
Old 04-15-2020, 01:05 PM   #17
Art Newland
Mart.
threads on the insert are 9/16″-18 OD. and 7/16″-24 ID. (standard).
The fuel line connection is the same as the Holley but where it threads into the carb it's 7/16. It's an expensive repair by the time you purchase the inlet, insert, proper drill and tap. Not to mention associated shipping costs.
"whatever works!"
Old 04-15-2020, 05:40 PM   #18
Art Newland
My Holley 94 experiment for the day.
"whatever works!"
Old 04-15-2020, 05:49 PM   #19
Mart
Mart's Avatar
Art, are you rethreading a pipe thread to 1/2-20? To make it a face seal instead of an olive (as we call them) fitting?
I actually went out to the garage (it's nearly midnight here) to check a 94 is 1/2 -20.
I began to doubt myself.
so, if I have this right, a stromberg has a brass fitting with a 7/16 thread into the carb. This brass fitting takes the normal 1/2" "ford" nut. this is adapted into a worn out or damaged holley by threading out to 9/16 and using an insert to adapt down to 7/16 to take the brass piece robbed from a stromberg?
I can see why you're using the lathe to get you out of a mess.
Mart
edit: "standard" (UNF) for 7/16 is a 20 tpi pitch. 24 is used on weatherhead fittings like brake pipes for 1/4" tube nuts.
Old 04-15-2020, 07:06 PM   #20
Art Newland
Mart
I think you got it!
I turned down this $3 fitting to .503 , smoothed out the threads in the carb with a .500 bit,
Added a bit of sleeve retainer and pressed it together.
"whatever works!"
