Old 04-13-2020, 02:48 AM   #1
my4dv8
Default Freeing up a frozen 36 speedometer
Hi , we have a couple of 36 speedometers, one with a somewhat rusty body and faded face and numbers they seems to function well . The one we want to use has a nice body and nice face ( don’t we all want that) but after 24 hrs with penetrating oil in the cable input end it still won’t budge. Am I looking at the wrong place for frozen?.
my4dv8 is offline   Reply With Quote
Old 04-13-2020, 03:05 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Freeing up a frozen 36 speedometer
There are 3 different types.Waltham,Delco and SW.The parts do not interchange.Is your bezel a push on or crimped on style?You need to remove the bezel,then the needle(maybe).The needle is that hardest to get off without damage as its on a tapered shaft.The screws on the back come off and the unit drops out for access to the mechanism.
Old 04-13-2020, 05:27 AM   #3
Terry,OH
Terry,OH's Avatar
There is usually a small oil cup take the plug out of the hole and add some light oil.
Old 04-13-2020, 04:01 PM   #4
my4dv8
I took the mechanism out of the case and soaked in penetrating oil where cable goes in but still no luck. It is a delco speedometer. Some say there is a Welch plug near where cable goes in , Found the little brass plug further down than I thought , removed it and the felt. Will wait and see.
Old 04-13-2020, 07:03 PM   #5
Ken/Alabama
Ken/Alabama's Avatar
Warm it up with a propane torch while trying to turn it. I’ve had pretty good luck freeing up some using heat.
Old 04-13-2020, 10:35 PM   #6
my4dv8
Thanks a bunch @Ken/Alabama . The gentle warming, give it a spin, warm it , give it a spin, third time it came good with a little more oil and a spin.
Old 04-13-2020, 10:48 PM   #7
Tinker
Tinker's Avatar
Heating it up might be just a temporally fix. Once it congeals again it might stick again. Might. Maybe a shot of brake cleaner and flush. Then re-oil. Lithium grease.
Old 04-14-2020, 04:06 AM   #8
my4dv8
Yup, did the brake cleaner thing too, then some degreaser , and lubed it. tested it on the bench with an electronic speed sensor to cable adapter , powered the adapter up , flipped all the switches and it read 60mph for 20 seconds and the odo read 3/10 more as Its supposed to .. So here’s hoping .
