Old 12-02-2019, 05:48 PM   #1
Russ/40
Russ/40's Avatar
Default That "Opportunity Knocks" Engine
It's back, the disastrous opportunity I couldn't pass up.
Sent the block to have it cleaned and Mag'd because it looked so good on top end. Well it failed me again, but, not so bad. Attached photos of the crack found. Now from every other crack I've seen posted here, it looks like a perfect candidate for the JB Weld approach. Not being a pressurized system, and it looks to be away from being a fatal crack. What say there barners? What would you do?
