Old 09-09-2019, 12:52 PM   #1
some mech 3
Default Transmission Gears Locked
After I lifted the Shifting Tower on my 1930 Roadster to inspect possible damaged gears I have been unable to get the two neutral gears in position so I can reinstall the tower. I have hand-cranked the engine to check the condition of the teeth on the gears and the main shaft and the cluster turn smoothly. But I cannot move the neutral gears horizontally to get them in the correct position. I have tried the various suggestions on several Ford Barn postings. None worked. I have changed the lubricant. I checked the shift tower, itself. I 'have the rear wheels jacked up, but that doesn't help. I can't get the transmission into gear so that I can rock the wheels because when I lifted the tower the transmission was in neutral. I will try any suggestions. Thank you in advance.
Some Mech3
some mech 3 is offline   Reply With Quote
