Long post but may help you help me solve this problem.
I have fuel leaking (draining) out of the carburetor afterstart attempts where it does not start. Almost seems like the intake is somehow feeding pressure into the carb.Fuel does not leak out statically only after a start attempt. OK so the story is after acquiring my family’s 1930 Model Acoupe I did a quick inventory of things it needed and the fuel system was inthe most obvious need due to an inoperative gas gauge, shutoff valve leak andinterior tank rust (sediment bowl needed cleaned) and a firewall to carb fuelline that was chaffed. I ran the tank dry (changed the gauge with no issues, theshutoff valve was removed to gain access to the tank low point to help in rustremoval. There was plenty of rust to be removed and this task probably needs tobe revisited with a better plan. I decided to inspect/clean the fuel shutoff valve and endedup replacing it due to deep scratches in the valve body causing it to leak. The sediment bowl was full of rust and after reading thisforum decided I better check the carburetor bowl; which was full of rustsediment as well. I replaced the carburetor gaskets (intake, float bowl (mainbody) and the fuel strainer and drain plug) I replace the fuel line from the firewall to the carb. Putabout two gallons in the tank checked for leaks, then opened up the shutoffvalve. NO LEAKS!! I then move the car out of the garage in case it caught onfire and tried to start the car. The car did not start right away which I anticipated and aftera few attempts noticed fuel coming out of the carburetor. I watched the start attempt after cleaning up and the gas is“draining” out of the carburetor after a start attempt. It almost seems likethe intake is somehow feeding pressure into the carb blowing the fuel out. Fueldoes not leak out statically only after a start attempt. After a few attempts (cleaning up gas after each attempt)the ca started and it ran fine. Upon shutdown no fuel drained out of the carb. Restarted and fuel drained each time it did not start. Nothing on the carb was adjusted or dismantled only gasketschanged. THOUGHTS? |
Sound like it's flooded, how long are you choking it??
Bob |
If you are choking it and it doesn't start, the gas will run out the carb.
One or two seconds MAX on each choke
Note choke only works when engine is turning. Do not mean to be insulting but there are many Utubes where they choke when engine is not turning. return choke to open ... it should start AFTER you release choke and while still cranking. then retry with another 1 or 2 ... if no start. If choke more than 1 or 2 seconds at a time it will leak out throat. Note some carbs start better if throttle is open slightly. One notch or so from when throttle plate first moves. Note keep this for cold weather: If engine starts using procedure above and dies after 2 seconds or so: Open GAV one turn and retry ... if still dies try another 1/2 turn or so. If 20 or 30 below it might take two turns total on GAV (gas adjustment valve.) Normal GAV position is 1/4 turn from closed after warm up ... do not force it. Last edited by Benson; 06-26-2019 at 11:43 PM. |
If you do not have one - There is a pencil style filter that can be added to the inlet of teh fuel shutoff, will keep teh shutoff from failing due to rust/junk getting into teh valve. This why you had deep scratches.
https://www.brattons.com/fuel-tank-filter-screen.html Once the fuel valve is fixed, you should be able to leave it on overnight and not have any leakage/drippage from the carb. If you do then you have carb issues, perhaps a leaky float valve or the float level is not set correctly. When the carb leaks and teh float Bowl is overfilling, it leaks into the Air intake, and then through a small weep hole in the bottom of the air intake. Drains down the side of the carb, and usually drips/runs off the bolt head on the bottom of the carb. So if you have a leak, use you pinky finger and feel on the inside bottom of the air intake to check for gas. The method above (Benson) is the correct way to start. In the 60s and before many cars you full choke using the cable/knob until it started and then backed off on the adjustment. On the A the full choke is used to prime/force rich fuel mixture into the intake manifold, release the choke and then it shoots into the cylinders. If some partial choke is needed to keep it running the CAV (Choke rod) is twisted for partial choke. This procedure is also used on old tractors except some do not have the GAV adjustment. Continuing to full choke floods them. Most of the time the Motor fires/runs after the 1-2 seconds of full choke, when the choke is removed, again a shot of leaner fuel air pushing the rich mixture into the cylinders. |
A leaky float valve will give the same result as having the float level too high. If it is (too high), fuel will leak into the throat of the carb and onto the gound Correctly set, the fiuel level is just short of this happening.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
Most 1930s and later carbs and others had choke pull offs, air bypasses in choke plate and later like QuadraJet, DualJet Automatic chokes and others and auto throttle advance devices and it was possible to choke and crank until they started and not flood it.
Or in auto chokes ... set the choke and crank. Model A has none of these features. Last edited by Benson; 06-26-2019 at 07:06 PM. |
Thanks for all the info I will read and reread a few time to try and get a better understanding of what each has said.
Pretty sure I was flooding it by over choking. Hey Benson no insult taken and please "insult" all you want; I have thick skin and need to learn. FYI, SORRY but I will not be starting the car at 20 or 30 below ... Just sayin ;-) 30 ClsdCab: I replaced the shutoff valve but fyi I do have a "filter" on the fuel shutoff but it is more of a "standpipe" with stainless steal mesh similar to the one you describe but has a copper tube that extends higher into the fuel. I think it was "made" to prevent increase rust sediment from entering the line. I have the shorter version you refer to but decided to reinstall the one that came off; seems to work good. I do think I will be cleaning this tank sooner than later. SO to start I should open the GAV a full turn (CCW) then return to closed then approx. 1/4 open Choke for 1-2 sec while cranking engine. I did not realize the choke sent a richer fuel schedule I thought it reduced the air to get a "richer" mixture by reducing the air. Are there any good animations on how these carburetors work? I will try tomorrow and post me results. THANKS AGAIN for all the HELP and lack of criticism. |
#10 | |
![]() Quote:
Most of have at one time been where you are, we are here to help. |
Here try this link 1st, more basic with animation, good starter info.
http://modelabasics.com/carb%20basics%202.htm |
Split the carb halves,and look at the bowl vent,where it vents to the atmosphere.It will be in the top half,to one side and just below the float bracket.It is a tiny hole,and if it gets plugged the air can't escape and the float won't rise to shut the valve off.I had a bug crawl in there in a newly done carb sitting on the bench for two days.I would start the car,it would run a little rich,and when I shut it off I would get a rush of gas out the throat. I have a small ultrasonic tank,and for some reason the bugs seem to like the smell of the parts after they have dried off.
#13 | |
![]() Quote:
Very nice! |
#14 |
Hey all wanted to share my (our) success with the choke and fuel leaking out of the carb.
Car started right up with no issues and ran like a champ! One of the "techniques" I have read is turning off the fuel and allowing the engine to continue running essentially emptying the carb of gas to prevent fumes or leaks. If this technique were to be used (it does make sense in a way) any ideas on how long after opening the shutoff valve would the carb have a full bowl and be ready to start? THANKS for all the HELP!! Love this car and forum. |
#15 | |
![]() Quote:
xxx |
#16 |
No more than 5 seconds
