Old 05-05-2019, 03:02 PM   #1
Nlbloch
Default Installing motometer
Looking for proper guidance to install new motometer so that I don’t mess up the radiator collar nor the new motometer. Do I need to loosen the Allen nuts so that it turns easily, or is there some other trick to this?
Nlbloch is offline   Reply With Quote
Old 05-05-2019, 04:07 PM   #2
bucket-o-rust
Default Re: Installing motometer
If you have ever tried to remove one that has been installed on a car that has sat in storage for many years you would not put one on your car. They get corroded and will not unscrew so you can take them apart. If they will not unscrew you will damage your radiator neck getting the thing off. If you have an old radiator it is OK but I would not use it on a new radiator. If you just have to have one use lots of anti seize on the threeds.
bucket-o-rust is offline   Reply With Quote
Old 05-05-2019, 05:22 PM   #3
midgetracer
midgetracer's Avatar
You must be talking about 28-29 radiators.
midgetracer is offline   Reply With Quote
Old 05-06-2019, 06:47 AM   #4
marty in Ohio
marty in Ohio's Avatar
Nlbloch,
To answer your question, yes, loosen the allen bolts and position the motometer in place. Before you tighten the bolts aim the meter so that you can see the thermometer from your driver's seat. I've had one on my '30 town sedan since I got it 26 years ago. It doesn't really tell me the temperature, but tells me when it's getting hot.
Marty
marty in Ohio is offline   Reply With Quote
Old 05-06-2019, 07:34 AM   #5
1928Mik
1928Mik's Avatar
Exactly what Marty says. I keep an eye on mine as well, good indicator when it's getting too hot.
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible 455 5 speed Restomod
1976 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 05-06-2019, 09:21 AM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
After a long run, if the Moto-Meter cycles up & down regularly, YOU ARE LOW ON WATER!!!
Bill Cool
"THE ASSISTANT GURU OF STUFF"
Old 05-07-2019, 07:22 AM   #7
chap52
chap52's Avatar
My motometer lets me know when the engine is getting overheated. The thought of running it with the thermometer in the "run temp circle" is not my cars reality zone. But when the "red" shows up on the bottom of the thermometer I just "slow my roll" and let it subside.
I ended up installing a temp gauge because the I was new to "A's" and running the motometer in the "running temp circle" caused a bit of windshield washing with the 50/50 mix from the radiator. So the motometer is a "heads-up" tool, and looks cool. Chap
Old 05-07-2019, 05:04 PM   #8
whirnot
whirnot's Avatar
Wink Re: Installing motometer
Mines been on there for over 30 years. No problem getting it off when I put a new radiator in last year.
I put a little Teflon tape on the threads to seal and protect.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 05-07-2019, 08:38 PM   #9
BILL WILLIAMSON
If the red stripe separates, partially cover the radiator & the lower stripe will connect to the upper stripe.
I've seen IDIOTS twirl the Moto-Meter on a rope, to make the stripes connect properly!!!!Bill Smarterthanthat
Old 05-08-2019, 09:37 AM   #10
Nlbloch
Thanks to everyone for your updates and insights. Much appreciated.
Old 05-08-2019, 04:27 PM   #11
F.M.
Look in a mirror, It works..
F.M. is offline   Reply With Quote
