Old 04-21-2019, 07:29 PM   #1
RalphM
RalphM's Avatar
Default 35 floor thickness?
Due to the lack of quality repop floors for my 35 Coupe, most of which are not even close to original( street rod style). I’ve decided to make my own, well on the flat ones anyway. 🙂
I made patterns from what’s left, but what is the thickness of the sheeting to match what’s there?
Most of my trunk area, and the kick up where the drive line passes through is the worst.
This car was an old Hot Rod from the 50’s, so not show quality by any means, but I want it to look right.
File Type: jpg 7D47BE35-5F4D-4A47-B425-AB2CDA570766.jpg (69.0 KB, 46 views)
RalphM is offline   Reply With Quote
Old 04-21-2019, 08:57 PM   #2
cas3
Default Re: 35 floor thickness?
i believe most automotive sheet metal is 18 ga. , or supposed to be
cas3 is online now   Reply With Quote
Old 04-21-2019, 09:15 PM   #3
RalphM
RalphM's Avatar
So looking on the inter web, depending on which chart you use, it can be somewhere between .047 to .051 thick steel?
Old 04-21-2019, 10:39 PM   #4
cas3
my antique starrett gauge no. 283 ! lists 18 gauge to be 050 thick. however, i think every piece of metal i ever checked was thinner than the gauge says. its not the gauge i suspect, its the metal they sell us now days
Old 04-21-2019, 10:59 PM   #5
DavidG
DavidG's Avatar
Isn't "original (street rod style)" an oxymoron?
Old 04-21-2019, 11:37 PM   #6
RalphM
RalphM's Avatar
LOL!
I meant the ones available are street rod style. Plus the fact that shipping floor pans to Alaska is very costly.
Old 04-22-2019, 09:20 PM   #7
quickchange34
quickchange34's Avatar
The Floor plans are 18 gauge .
quickchange34 is offline   Reply With Quote
Old 04-23-2019, 10:00 AM   #8
rotorwrench
rotorwrench's Avatar
There are a lot of different gauges. Ford went by US Standard Revised Gauge. This is close to .047" thickness at 18 gauge. Ford had their own rolling mill so they could make it whatever thickness they wanted to.
I purchase the AKDQ (aluminum killed draw quality) type steel to make it easier to form. Its quicker if a person has dies but it can be done on a steel table with various forming tools and hammers. The last sheets I purchased were from Stock Car Steel. They have a web-site. Bradley has special steel forms cut for him to do his forming process but it takes forever for him to fabricate one for a customer. His work is excellent but the complaints are just too many to trust him to get the job done.
Old 04-23-2019, 04:45 PM   #9
RalphM
RalphM's Avatar
Local steel supply doesn’t have anything thinner than .062, but I called a place that makes roofing and gutters and they say they have some cold rolled at 18 gauge. Have to get over there and look at it to see if it’s the right stuff. Neither one of them knew what AKDQ steel was.
Old 04-23-2019, 06:08 PM   #10
tubman
tubman's Avatar
I also would like to learn more about this "AKDQ" steel.
Old 04-23-2019, 06:32 PM   #11
JSeery
JSeery's Avatar
"DQAK is an acronym for Drawing Quality Aluminum Killed. The base metal is 1008 Drawing Quality Steel. As compared with sheets of commercial quality, Drawing Quality Aluminum Killed sheet has a greater degree of ductility and is more consistent in performance, using specially killed steel with Aluminum as the deoxiclizing agent."
https://stockcarsteel.com/cold-rolle...ak-steel-sheet
https://www.myalro.com/gradeinfo/Met...t.aspx?gp=0352
HAMB thread on topic: https://www.jalopyjournal.com/forum/...to-use.786599/
Old 04-23-2019, 06:41 PM   #12
wamnram
wamnram's Avatar
Do a web search on DQAK Steel;
DRAWING QUALITY - ALUMINUM KILLED (DQAK) - Specially killed steel using aluminum as the deoxiclizing agent. "
Wayne
wamnram is offline   Reply With Quote
Old 04-29-2019, 08:24 PM   #13
RalphM
RalphM's Avatar
So I found some steel, had the panels cut. They look OK but I thought I’d measure them today and I came up with .057 thickness, which is a tad on the heavy side. Hopefully it won’t be too hard to roll a bead in them. Plus side is, they did a real good job of cutting and bending them to just what I wanted. Not too bad a price either cost me I think $65 for everything, three pieces.
I would have to of paid double that for the pieces to be shipped here.
But after all the work I’ve done on my fenders I cannot believe they are the same thickness of steel. Seems like they are a lot thinner.
