Old 04-01-2019, 03:26 AM   #1
Werner
Werner's Avatar
Default V-belt and very small pulleye
Hello at all, I have a question about the V-belt.
I'm currently building in Brattons alternator. The type, almost looks like the original one. The pulley has a very small diameter. There are V-belts that have teeth down inside. They are better suited for a very narrow radius.
Has someone installed it and drives it well? Thank you for advice in advance.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 04-01-2019, 09:50 AM   #2
redmodelt
redmodelt's Avatar
Default Re: V-belt and very small pulleye
Werner;
I know a number of people that use that style belt with the alternator. Yes it works fine. You are correct about the smaller pulley not working well with the original style belt.
Old 04-01-2019, 04:32 PM   #3
arnhemmer
Go with the castellated belt, I tried the original style belt when I went with the alternator and they kept braking. I think that the pulley diameter is too small for the original belt. The castellated belt is more flexible and has a better grip so it does not need to be very tight thus saving the water pump bearing.
arnhemmer is offline   Reply With Quote
Old 04-01-2019, 06:46 PM   #4
Jim/GA
Jim/GA's Avatar
Yes, this is the style belt I use. It gives a good grip to the pulley without excessive pressure on the bearings in the water pump.
Jim Cannon
"Spread the Joy! Have a Model A day!"
Old 04-01-2019, 10:21 PM   #5
Gold Digger
I made new steel pulleys for both my alternator cars. I didn't like the small diameter and belt contact. I was concerned at first about them not turning the alternators fast enough but I can't tell there's any problem at all.
Gold Digger is offline   Reply With Quote
