Old 02-08-2019, 05:06 AM   #1
frankfalcone
Default Numbered steering column
Original steering column numbers
My car is 91 years old on February 14 when It was aquired there was 87000 miles,last registration was 57 years ago. Everything was original and when I show the car there is a lot of people who say I have never seen that before. The steering column is numbered at the base above the open bail light switch #14678 floor # A16455 engine #A24981 I have never seen this before and am wondering if anyone else has. Just from the # there should be plenty.
File Type: jpg 2C609208-A9EF-4825-85A9-4CE55B56F918.jpg (31.0 KB, 97 views)
frankfalcone is offline   Reply With Quote
Old 02-08-2019, 05:46 AM   #2
KansasRick
Default Re: Numbered steering column
Pictures please.
KansasRick is offline   Reply With Quote
Old 02-08-2019, 07:54 AM   #3
Joe K
Joe K's Avatar
Open bail type switch? As in the "earliest" switch? I'm assuming this a 7 tooth pattern steering column?
Upper left in the pix.
Joe K
Shudda kept the horse.
Old 02-08-2019, 11:46 AM   #4
d.j. moordigian
d.j. moordigian's Avatar
You originally said you had no weld seam,....now you have a weld seam in this post.
https://www.fordbarn.com/forum/showt...teering+column
d.j. moordigian is offline   Reply With Quote
