Old 02-09-2019, 09:56 AM   #1
russcc
Default '38-48 Lincoln engine parts catalog.
Anyone have a Lincoln engine parts catalog ? I would like to find out what they specs are for the 86H-6513 valve spring. For example, the green bible lists the 78-6513 as 2.41 length, 11.5 coils. I have checked those Ford springs, and the specs are on the money. I would like to know if the specs for the 86H-6513 are listed, and what the are. Thank you Fordbarners.
Old 02-09-2019, 01:18 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: '38-48 Lincoln engine parts catalog.
I don't know the exact specs on the V12 springs but they are slightly taller, have 8 coils give or take and have a tension about 10 lbs more than the equivalent Ford springs. All in all, it's not a lot of difference. I think they check out at about 51 pounds at install height but that can be changed pretty easily.
Old 02-09-2019, 07:18 PM   #3
russcc
Thank you. Right on target. Motors Repair manual specs are 51#s at an installed height of 2.125. What I would like to know is, does the Lincoln engine parts catalog show the height of the spring, and number of coils like the 78-6513 in the green bible.
Old 02-10-2019, 09:46 AM   #4
russcc
Anyone have the Lincoln parts catalog ?
Old 02-10-2019, 10:19 AM   #5
deuce5wndw
deuce5wndw's Avatar
I have the 38-48 catalog but it doesn't list the specs just the color. 86H-6513 are brown or green in color
deuce5wndw is offline   Reply With Quote
